I am leaning to think that the issue is around it making the selections too fast or something like that.
Because if I just try the same selection a few times in a row, then it makes it through every test fine.
for index in range(3):
try:
variant_dropdown.select_option_by_text_if_not_selected(
variant.title()
break
except AssertionError as e:
if index == 2:
raise e
continue
EDIT:
I am thinking maybe its something more global, I am noticing that I am seeing a similar inconsistency with setting values on a numeric input as well.
test_sizes = [12, 16, 20, 24]
for size in test_sizes:
# Set width via numeric input
self.width_input.set_text(str(size))
# Reduced wait time
self.test_page.wait_for_binding_propagation(0.2)
# Verify the input value was set correctly
def check_size():
actual_value = self.width_input.get_text()
return actual_value == str(size)
assert self.test_page.wait_with_retry(
check_size, max_attempts=5, wait_between=0.2
), f"Expected width '{size}', got '{self.width_input.get_text()}'"
Where every once and awhile it seems to "miss" the events to either click/write data into things. Specifically with the input field its with that self.width_input.set_text(str(size)) getting "missed".
For some additional info:
Here is my webdriver
import os
import logging
from selenium import webdriver
from selenium.webdriver.chrome.service import Service
logger = logging.getLogger(__name__)
def get_webdriver(executor_url, browser="chrome", headless=None):
Initialize Selenium WebDriver with optimized settings for CI/CD.
Args:
executor_url (str): Selenium Grid/Remote WebDriver URL
browser (str): Browser type (currently only 'chrome' supported)
headless (bool): Force headless mode. If None, auto-detect based on environment
Returns:
WebDriver instance
if browser.lower() != "chrome":
raise ValueError(f"Unsupported browser: {browser}")
# Auto-detect headless mode for CI environments
if headless is None:
headless = bool(os.getenv("CI")) or bool(os.getenv("GITHUB_ACTIONS"))
logger.info(f"Initializing {browser} WebDriver (headless: {headless})")
logger.info(f"Executor URL: {executor_url}")
# Chrome options optimized for CI/CD
options = webdriver.ChromeOptions()
# SSL and certificate handling
options.add_argument("--ignore-ssl-errors=yes")
options.add_argument("--ignore-certificate-errors")
options.add_argument("--ignore-certificate-errors-spki-list")
options.add_argument("--ignore-ssl-certificate-errors")
options.add_argument("--allow-running-insecure-content")
# Performance and stability options
options.add_argument("--no-sandbox")
options.add_argument("--disable-dev-shm-usage")
options.add_argument("--disable-gpu")
options.add_argument("--disable-web-security")
options.add_argument("--disable-features=VizDisplayCompositor")
options.add_argument("--disable-extensions")
options.add_argument("--disable-plugins")
options.add_argument("--disable-images") # Speed up loading
options.add_argument("--disable-javascript-harmony-shipping")
# Window size (important for element visibility)
options.add_argument("--window-size=1024,768")
options.add_argument("--start-maximized")
# # Headless mode for CI
if headless:
options.add_argument("--headless")
logger.info("Running in headless mode")
# Logging preferences
options.add_argument("--log-level=3") # Suppress INFO, WARNING, ERROR
options.add_experimental_option("excludeSwitches", ["enable-logging"])
options.add_experimental_option("useAutomationExtension", False)
# Set capabilities (W3C compliant)
options.set_capability("acceptInsecureCerts", True)
# Note: acceptSslCerts is deprecated in favor of acceptInsecureCerts
# Additional capabilities are now set through options
options.set_capability("goog:loggingPrefs", {"browser": "SEVERE"})
try:
# Create remote WebDriver (Selenium 4+ syntax)
driver = webdriver.Remote(command_executor=executor_url, options=options)
# Set timeouts
driver.set_page_load_timeout(60)
driver.set_script_timeout(30)
logger.info("WebDriver initialized successfully")
logger.info(
f"Browser: {driver.capabilities.get('browserName')} {driver.capabilities.get('browserVersion')}"
return driver
except Exception as e:
logger.error(f"Failed to initialize WebDriver: {e}")
raise
def is_ci_environment():
"""Check if running in a CI/CD environment."""
ci_indicators = [
"CI",
"CONTINUOUS_INTEGRATION",
"GITHUB_ACTIONS",
"TRAVIS",
"CIRCLECI",
"JENKINS_URL",
"BUILDKITE",
return any(os.getenv(indicator) for indicator in ci_indicators)
def get_browser_logs(driver):
Retrieve browser console logs for debugging.
Args:
driver: WebDriver instance
Returns:
List of log entries
try:
logs = driver.get_log("browser")
if logs:
logger.info(f"Retrieved {len(logs)} browser log entries")
return logs
logger.warning(f"Could not retrieve browser logs: {e}")
return []
def capture_network_logs(driver):
Capture network activity logs if available.
Args:
Returns:
List of network log entries
try:
logs = driver.get_log("performance")
network_logs = [log for log in logs if "Network." in log.get("message", "")]
if network_logs:
logger.info(f"Retrieved {len(network_logs)} network log entries")
return network_logs
logger.warning(f"Could not retrieve network logs: {e}")
return []
Here is my test fixture page
import time
from selenium.webdriver.common.by import By
from selenium.webdriver.remote.webdriver import WebDriver
from selenium.webdriver.support import expected_conditions as EC
from selenium.webdriver.support.ui import WebDriverWait
from selenium.common.exceptions import TimeoutException
from ignition_automation_tools.Pages.PerspectivePageObject import PerspectivePageObject
# Import standard Ignition components for interacting with controls
from ignition_automation_tools.Components.PerspectiveComponents.Inputs.Dropdown import (
Dropdown,
class TestFixturePage(PerspectivePageObject):
Page object for the test fixture page that renders components by ID.
Simply navigates to /test/test-fixture/{componentId} and waits for the component to render.
def __init__(self, driver: WebDriver, gateway_address: str):
super().__init__(
driver=driver,
gateway_address=gateway_address,
page_config_path="/test/test-fixture",
primary_view_resource_path="Test Fixture",
configured_tab_title="Test Fixture",
def _wait_for_page(self):
"""Wait for the component view to be visible."""
WebDriverWait(self.driver, 60).until(
EC.visibility_of_element_located((By.ID, "component-view"))
def navigate_to_component(self, component_id: str):
Navigate to a specific component test page.
:param component_id: The component ID to navigate to (e.g., 'shadcn.input.button')
# Build the full URL with component ID
component_url = f"{self.url}/{component_id}"
# If we are not already at the component URL, navigate to it
if self.driver.current_url != component_url:
# Navigate directly to the component page
self.driver.get(component_url)
# Wait for the component view to be ready
self._wait_for_page()
def navigate_to(self):
"""Navigate to the base test fixture page (without component)."""
self.driver.get(self.url)
# Note: Don't wait for component-view here since no component is loaded yet
self.wait_for_perspective_page()
# Generic wait utilities for test synchronization
def wait_for_binding_propagation(self, duration: float = 0.5):
Wait for data binding propagation to complete.
:param duration: Time to wait in seconds (default 0.5s)
time.sleep(duration)
def wait_for_ui_update(self, duration: float = 0.2):
Wait for UI updates to complete after user interactions.
:param duration: Time to wait in seconds (default 0.2s)
def wait_for_animation(self, duration: float = 0.2):
Wait for CSS animations/transitions to complete.
def wait_for_element_change(
self, locator, timeout: float = 5.0, poll_frequency: float = 0.1
Wait for any element to change (useful for dynamic content).
This compares the element's outer HTML before and after to detect changes.
:param locator: Tuple of (By, locator_string)
:param timeout: Maximum time to wait in seconds
:param poll_frequency: How often to check for changes in seconds
:return: True if element changed, False if timeout
try:
element = WebDriverWait(self.driver, timeout).until(
EC.presence_of_element_located(locator)
initial_html = element.get_attribute("outerHTML")
end_time = time.time() + timeout
while time.time() < end_time:
time.sleep(poll_frequency)
try:
current_element = self.driver.find_element(*locator)
current_html = current_element.get_attribute("outerHTML")
if current_html != initial_html:
return True
except:
# Element might have been recreated, consider this a change
return True
return False
except TimeoutException:
return False
def wait_for_element_stable(
self, locator, stability_duration: float = 1.0, timeout: float = 10.0
Wait for an element to remain stable (unchanged) for a specified duration.
Useful when you need to ensure an element has finished updating.
:param stability_duration: How long element must remain unchanged
:param timeout: Maximum time to wait for stability
:return: True if element became stable, False if timeout
try:
last_change_time = time.time()
last_html = element.get_attribute("outerHTML")
time.sleep(0.1)
try:
if current_html != last_html:
# Element changed, reset stability timer
last_html = current_html
elif time.time() - last_change_time >= stability_duration:
# Element has been stable for required duration
return True
except:
# Element disappeared or error occurred
return False
return False
def wait_with_retry(
self,
check_function,
max_attempts: int = 5,
wait_between: float = 0.2,
Retry a check function multiple times with waits between attempts.
:param check_function: Function that returns True when condition is met
:param max_attempts: Maximum number of attempts (reduced from 10 to 5)
:param wait_between: Time to wait between attempts in seconds (reduced from 0.5 to 0.2)
:return: True if check_function eventually returned True, False otherwise
for attempt in range(max_attempts):
if check_function():
return True
if attempt < max_attempts - 1: # Don't wait after the last attempt
time.sleep(wait_between)
return False
def set_dropdown_value(
self, dropdown: Dropdown, option_text: str, repeats: int = 3
for index in range(repeats):
try:
dropdown.select_option_by_text_if_not_selected(option_text)
break
if index == repeats - 1:
raise e
continue
Here is my test configuration
import os
import logging
import pytest
from utils.logging import setup_logging, configure_debug_mode
from utils.webdriver import get_webdriver
from utils.paths import TEMP_DIR, SCREENSHOT_DIR, LOG_DIR
from utils.screenshots import save_screenshot
Import from the test-specific pages directory (not library)
from pages.test_fixture_page import TestFixturePage
Environment-based configuration with sensible defaults
SELENIUM_EXECUTOR_URL = os.getenv(
"SELENIUM_EXECUTOR_URL", "https://selenium-executor.localtest.me/wd/hub"
GATEWAY_URL = "http://shadcn:8088"
Setup directories
os.makedirs(TEMP_DIR, exist_ok=True)
os.makedirs(SCREENSHOT_DIR, exist_ok=True)
os.makedirs(LOG_DIR, exist_ok=True)
def pytest_addoption(parser):
"""Add custom command line options."""
parser.addoption(
"--debug-automation", # Changed from --debug to avoid conflicts
action="store_true",
default=False,
help="Enable debug logging for all libraries (selenium, urllib3, etc.)",
parser.addoption(
"--log-selenium",
default=False,
help="Enable selenium debug logging specifically",
parser.addoption(
"--log-requests",
default=False,
help="Enable requests/urllib3 debug logging",
def pytest_configure(config):
"""Configure pytest with custom markers and logging settings."""
# Configure debug logging based on command line options
debug_mode = config.getoption("--debug-automation") # Changed from --debug
log_selenium = config.getoption("--log-selenium")
log_requests = config.getoption("--log-requests")
configure_debug_mode(
debug_mode=debug_mode, log_selenium=log_selenium, log_requests=log_requests
# Add custom markers
config.addinivalue_line(
"markers", "slow: marks tests as slow (deselect with '-m \"not slow\"')"
config.addinivalue_line("markers", "integration: marks tests as integration tests")
"markers", "smoke: marks tests as smoke tests for quick validation"
"markers",
"quit_on_failure: marks tests that should quit the entire test session if they fail",
"markers", "component: marks tests that test individual components"
"markers", "variants: marks tests that test component variants"
"markers", "debug: marks tests that need debug logging enabled"
Setup logging after pytest configuration
logger = setup_logging()
Log configuration for debugging (only in debug mode)
if logger.isEnabledFor(logging.DEBUG):
logger.debug(f"Selenium Executor URL: {SELENIUM_EXECUTOR_URL}")
logger.debug(f"Gateway URL: {GATEWAY_URL}")
else:
logger.info("Test suite initialized (use --debug-automation for verbose logging)")
@pytest.fixture(scope="session")
def gateway_url():
"""Provide the Ignition gateway URL from environment or default."""
return GATEWAY_URL
def selenium_executor_url():
"""Provide the Selenium executor URL from environment or default."""
return SELENIUM_EXECUTOR_URL
def driver(selenium_executor_url, request):
debug_enabled = logger.isEnabledFor(logging.DEBUG)
if debug_enabled:
logger.debug(f"Connecting to Selenium at: {selenium_executor_url}")
driver = get_webdriver(executor_url=selenium_executor_url)
yield driver
if debug_enabled:
logger.debug("Closing WebDriver session")
driver.quit()
@pytest.fixture(scope="function", autouse=True)
def reset_browser(driver, test_fixture_page):
driver.delete_all_cookies()
test_fixture_page.navigate_to() # Navigate to base URL
yield
@pytest.fixture(scope="function")
def test_fixture_page(driver, gateway_url, request):
"""Create the test fixture page (without navigating to any component)."""
debug_this_test = request.node.get_closest_marker("debug") is not None
if debug_enabled or debug_this_test:
logger.debug(f"Creating test fixture page for {gateway_url}")
return TestFixturePage(driver=driver, gateway_address=gateway_url)
Enhanced error handling with screenshots
@pytest.hookimpl(tryfirst=True)
def pytest_runtest_setup(item):
"""Log test start."""
# Only log test start in debug mode or for debug-marked tests
debug_this_test = item.get_closest_marker("debug") is not None
logger.debug(f"Starting test: {item.name}")
def pytest_runtest_teardown(item, nextitem):
"""Log test completion."""
# Only log completion in debug mode or for debug-marked tests
logger.debug(f"Completed test: {item.name}")
@pytest.hookimpl(tryfirst=True, hookwrapper=True)
def pytest_runtest_makereport(item, call):
"""Hook to capture test results and handle failures with enhanced debugging."""
outcome = yield
report = outcome.get_result()
# Add extra information for failed tests
if report.when == "call" and report.outcome == "failed":
# Always log test failures (not just in debug mode)
logger.error(f"β Test {item.name} failed")
# Capture enhanced debugging info if driver is available
if hasattr(item, "funcargs"):
driver = item.funcargs.get("driver")
if driver:
try:
current_url = driver.current_url
page_title = driver.title
logger.error(f"π Failure context - URL: {current_url}")
logger.error(f"π Page title: {page_title}")
# Save screenshot for failed test
screenshot_path = save_screenshot(driver, item.name, "failure")
logger.error(f"πΈ Screenshot saved: {screenshot_path}")
# Only show browser logs in debug mode or if specifically requested
# Log browser console errors
from utils.webdriver import get_browser_logs
browser_logs = get_browser_logs(driver)
if browser_logs:
logger.debug("π₯οΈ Browser console errors:")
for log in browser_logs[-5:]: # Last 5 errors
logger.debug(f" {log}")
else:
logger.debug("π₯οΈ No browser console errors found")
logger.warning(f"β οΈ Could not capture failure details: {e}")
# Handle quit_on_failure marker
if item.get_closest_marker("quit_on_failure"):
logger.error("=" * 80)
logger.error(
"π¨ CRITICAL FAILURE: Test marked with 'quit_on_failure' has failed!"
logger.error(f"π¨ Failed test: {item.name}")
logger.error("π¨ Stopping all test execution immediately.")
pytest.exit(
f"Test '{item.name}' marked with 'quit_on_failure' failed. Stopping all tests.",
returncode=1,
Health check fixtures for CI
@pytest.fixture(scope="session", autouse=True)
def verify_services_health(gateway_url, selenium_executor_url, request):
"""Verify that required services are accessible before running tests."""
import requests
# Allow skipping health checks if needed
if os.getenv("SKIP_HEALTH_CHECKS", "").lower() in ("true", "1", "yes"):
logger.info("βοΈ Skipping service health checks (SKIP_HEALTH_CHECKS=true)")
return
if debug_enabled:
logger.debug("π Verifying service health...")
else:
logger.info("π Checking services...")
# Check Selenium
try:
response = requests.get(
selenium_executor_url.replace("/wd/hub", "/status"), timeout=10
if response.status_code == 200:
logger.info("β
Selenium service is healthy")
else:
pytest.fail(f"Selenium service returned status {response.status_code}")
pytest.fail(f"β Cannot connect to Selenium service: {e}")
if debug_enabled:
logger.debug("β
Service health checks completed")
