Issue after Ignition Server Restart
Good Morning,
Our ignition server restarted over the weekend are are running at Windows 10 box and our version of Igntion is 8.1 nad Java Version 17.0.8+7-LTS
We had a few older connects to some windows xp SQL server 2008 R2 pcs that worked just fine before the restart but now they are faulted with the below error.
java.sql.SQLException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "SQL Server did not return a response. The connection has been closed. ClientConnectionId:de86f50a-de5b-488c-9eb8-59270813b386".)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:587)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "SQL Server did not return a response. The connection has been closed. ClientConnectionId:de86f50a-de5b-488c-9eb8-59270813b386".
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:2670)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1837)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:2257)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:1921)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1762)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1077)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:623)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652)
... 12 more
Caused by: javax.net.ssl.SSLException: SQL Server did not return a response. The connection has been closed. ClientConnectionId:de86f50a-de5b-488c-9eb8-59270813b386
at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source)
at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source)
at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1767)
... 21 more
Caused by: java.io.IOException: SQL Server did not return a response. The connection has been closed. ClientConnectionId:de86f50a-de5b-488c-9eb8-59270813b386
at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.ensureSSLPayload(IOBuffer.java:780)
at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.readInternal(IOBuffer.java:836)
at com.microsoft.sqlserver.jdbc.TDSChannel$SSLHandshakeInputStream.read(IOBuffer.java:827)
at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.readInternal(IOBuffer.java:1009)
at com.microsoft.sqlserver.jdbc.TDSChannel$ProxyInputStream.read(IOBuffer.java:997)
at java.base/sun.security.ssl.SSLSocketInputRecord.read(Unknown Source)
at java.base/sun.security.ssl.SSLSocketInputRecord.readHeader(Unknown Source)
at java.base/sun.security.ssl.SSLSocketInputRecord.decode(Unknown Source)
... 27 more
8.1.35 (b2023120517)
Azul Systems, Inc. 17.0.8
Note I have went and took out tls1.0 and tls 1.1 disabled from the java.security path in the igntion folder and no dice anyone got anything else I could try.
This looks like a network/firewall issue. Maybe new rules that didn't affect your existing connections.
I am running JDBC 6.4.0.jre8.jar for the mssql jdbc driver
Windows firewall is disabled on both machines no network changes they are going through a dummy switch directly to each over
This is as blindingly obvious a network/firewall error as there can be. It isn't Ignition.
Are you certain SQL server is running and can be connected to with anything else? Try SQL Server Management Tools.
SSMS studio works from the same machine with same credentials
Got it resolved I had to disable 3DES_EDE_CBC in the java security file I found this on this form post java.sql.SQLException after migration 7.9 to 8.1 and with SQL Server 2005 Database Connection - Ignition - Inductive Automation Forum
Was the java.security file 3DES_EDE_CBC being blocked in the ignitnio security not direclty the firewall on the pc like I said we dont acutlaly have a firewall in place thanks though
I would question then if it was actually working prior to the restart of the computer. If this wasn't disabled previously, then how was it working before?
Could have been updated or changed I know we were having an Issue with the service and created a new ignition service with a new install so that could be it, but I was not involved with that the PLC guy was I am more database IT guy but thanks for your help! (So that file could have been reset)
If they re-installed, it most definitely was reset and most likely someone previously applied the same fix.
