Just Curious if its possible
Right now our supervisors are using attendance sheets that have been created using excel. They pull up these sheets and print them off each day to provide to the coordinators to check off which employees are at work for each department. Is it possible to recreate these using ignition and just have the supervisors print them off from ignition? I am including a copy of one of these for reference.1ST SHIFT PRODUCTION SCHEDULE.xlsx (52.0 KB)
Sounds like a great way to leverage the reporting module!
Sounds like an opportunity to go paperless…
I just finished a conversion of a few different excel sheets/vba scripts. I used powertables for the reporting side of it since I find doing that is so much easier than using the reporting module.
So yes, most definitely it is possible.
