Login screen not shown
Hi, I am new here, just installed 8.1.9 version and started Designer Launcher. It discovered designer with gateway on my local PC but when I click Open Designer I see Login in the taskbar but no Window appears. I can just close the window from taskbar. Where could be the problem ?
Windows 10
In your home directory there should be a .ignition/clientlauncher-data folder with a file called designerlauncher.log - can you paste the contents of that file here?
INFO  [DesignerLauncher              ] [2021/08/22 20:26:10]: Set initial logging level to INFO
INFO  [DesignerLauncher              ] [2021/08/22 20:26:10]: Updating logging level to INFO
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:13]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:27]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:29]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:31]: Matching client IP found, setting default gateway
INFO  [GatewayConnect                ] [2021/08/22 20:26:34]: Attempting to connect to gateway http://169.254.16.179:8088...
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:34]: Matching client IP found, setting default gateway
INFO  [GatewayCommUtil               ] [2021/08/22 20:26:35]: Downloading "http://169.254.16.179:8088/system/launchbin/launchclient.jar" (timeout=30)...
INFO  [GatewayCommUtil               ] [2021/08/22 20:26:35]: Starting download of 4690305 bytes
INFO  [LaunchUtil                    ] [2021/08/22 20:26:35]: Starting Java with the following parameters: C:\Program Files\Inductive Automation\Designer Launcher\jre\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://169.254.16.179:8088 -Djavaws.sr.launchts=1629656795518 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:40]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:45]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:51]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:26:56]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:27:02]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:27:07]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:27:12]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:27:18]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:27:23]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:27:29]: Matching client IP found, setting default gateway
INFO  [MulticastReceiverService      ] [2021/08/22 20:27:34]: Matching client IP found, setting default gateway
INFO  [GatewayConnect                ] [2021/08/22 20:29:59]: Attempting to connect to gateway http://169.254.16.179:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:30:00]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://169.254.16.179:8088 -Djavaws.sr.launchts=1629657000532 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [GatewayConnect                ] [2021/08/22 20:33:12]: Attempting to connect to gateway http://169.254.16.179:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:33:13]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://169.254.16.179:8088 -Djavaws.sr.launchts=1629657193777 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [DesignerLauncher              ] [2021/08/22 20:33:28]: Set initial logging level to INFO
INFO  [DesignerLauncher              ] [2021/08/22 20:33:28]: Updating logging level to INFO
INFO  [GatewayConnect                ] [2021/08/22 20:33:35]: Attempting to connect to gateway http://169.254.16.179:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:33:36]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://169.254.16.179:8088 -Djavaws.sr.launchts=1629657216785 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [GatewayConnect                ] [2021/08/22 20:33:58]: Attempting to connect to gateway http://169.254.16.179:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:33:59]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://169.254.16.179:8088 -Djavaws.sr.launchts=1629657239800 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [GatewayConnect                ] [2021/08/22 20:36:13]: Attempting to connect to gateway http://192.168.0.3:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:36:14]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://192.168.0.3:8088 -Djavaws.sr.launchts=1629657374998 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [DesignerLauncher              ] [2021/08/22 20:49:04]: Set initial logging level to INFO
INFO  [DesignerLauncher              ] [2021/08/22 20:49:04]: Updating logging level to INFO
INFO  [GatewayConnect                ] [2021/08/22 20:49:11]: Attempting to connect to gateway http://192.168.0.3:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:49:12]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://192.168.0.3:8088 -Djavaws.sr.launchts=1629658152903 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [GatewayConnect                ] [2021/08/22 20:53:40]: Attempting to connect to gateway http://192.168.0.3:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:53:41]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://192.168.0.3:8088 -Djavaws.sr.launchts=1629658421552 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [DesignerLauncher              ] [2021/08/22 20:56:56]: Set initial logging level to INFO
INFO  [DesignerLauncher              ] [2021/08/22 20:56:56]: Updating logging level to INFO
INFO  [GatewayConnect                ] [2021/08/22 20:57:02]: Attempting to connect to gateway http://192.168.0.3:8088...
INFO  [LaunchUtil                    ] [2021/08/22 20:57:04]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://192.168.0.3:8088 -Djavaws.sr.launchts=1629658624346 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [DesignerLauncher              ] [2021/08/22 21:48:35]: Set initial logging level to INFO
INFO  [DesignerLauncher              ] [2021/08/22 21:48:35]: Updating logging level to INFO
INFO  [GatewayConnect                ] [2021/08/22 21:48:41]: Attempting to connect to gateway http://192.168.0.3:8088...
INFO  [LaunchUtil                    ] [2021/08/22 21:48:43]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://192.168.0.3:8088 -Djavaws.sr.launchts=1629661723181 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
INFO  [DesignerLauncher              ] [2021/08/22 21:49:14]: Set initial logging level to INFO
INFO  [DesignerLauncher              ] [2021/08/22 21:49:14]: Updating logging level to INFO
INFO  [GatewayConnect                ] [2021/08/22 21:49:29]: Attempting to connect to gateway http://169.254.16.179:8088...
INFO  [LaunchUtil                    ] [2021/08/22 21:49:31]: Starting Java with the following parameters: C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://169.254.16.179:8088 -Djavaws.sr.launchts=1629661771039 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
Ok, great. Now can you open a command prompt and run this command (copy/paste from the logs):
Any error messages after it runs?
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by de.javasoft.plaf.synthetica.SyntheticaLookAndFeel (file:/C:/Users/stefa/.ignition/cache/resources/platform/synthetica-3.4.0.jar/0000000027D0B8E3/synthetica-3.4.0.jar) to method sun.swing.DefaultLookup.setDefaultLookup(sun.swing.DefaultLookup)
WARNING: Please consider reporting this to the maintainers of de.javasoft.plaf.synthetica.SyntheticaLookAndFeel
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
and also
Starting Bootstrap Loader v3.0
sun.awt.image.PNGImageDecoder$PNGException: crc corruption
        at java.desktop/sun.awt.image.PNGImageDecoder.getChunk(Unknown Source)
        at java.desktop/sun.awt.image.PNGImageDecoder.getData(Unknown Source)
        at java.desktop/sun.awt.image.PNGImageDecoder.produceImage(Unknown Source)
        at java.desktop/sun.awt.image.InputStreamImageSource.doFetch(Unknown Source)
        at java.desktop/sun.awt.image.ImageFetcher.fetchloop(Unknown Source)
        at java.desktop/sun.awt.image.ImageFetcher.run(Unknown Source)
Connect Step [attempt 1] connecting to: http://169.254.16.179:8088...
Downloading manifest at http://169.254.16.179:8088/system/launchmf/D?os=windows&arch=x64
...connect successful
Successfully downloaded launch manifest:
Hmm, anything else? Can you post the whole thing here?
Microsoft Windows [Version 10.0.19041.1110]
(c) Microsoft Corporation. All rights reserved.
C:\Users\stefa>C:\Users\stefa\.ignition\cache\resources\runtimes\11.0.11\bin\java.exe -classpath C:\Users\stefa\.ignition\cache\resources\platform\launchclient.jar\000000009D956105\launchclient.jar -Djavaws.sr.gateway.addr.0=http://169.254.16.179:8088 -Djavaws.sr.launchts=1629661771039 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
<?xml version="1.0" encoding="UTF-8"?>
<launch scope="D" framework="7" jreVersion="11.0.11" useCondensedDialogFont="false">
        <module name="" build="2021080617">
                <jar name="jide-shortcut-3.7.4.jar" crc="69D867D1" length="80404"/>
                <jar name="jide-dock-3.7.4.jar" crc="5A8E7A8" length="383828"/>
                <jar name="jyiconfonts-3.4.0.jar" crc="D1221784" length="1142774"/>
                <jar name="miglayout-core-4.2.jar" crc="FEECEF57" length="66663"/>
                <jar name="kotlin-stdlib-common-1.4.10.jar" crc="269DE677" length="191211"/>
                <jar name="commons-collections4-4.4.jar" crc="6847F0D3" length="751914"/>
                <jar name="client-api-8.1.9.jar" crc="5BCB639E" length="3218962"/>
                <jar name="jose4j-0.7.2.jar" crc="5975173E" length="265782"/>
                <jar name="kotlinx-coroutines-core-1.4.1.jar" crc="C25969D4" length="1672388"/>
                <jar name="common.jar" crc="916F97EB" length="3538874"/>
        </module>
        <module name="com.inductiveautomation.symbol-factory" build="2021080617">
                <jar name="__2310755172__vision-symbol-factory-7.1.9.jar" crc="1FCDA1C8" length="35496398"/>
        </module>
        <module name="com.inductiveautomation.alarm-notification" build="2021080617">
                <jar name="__210612271__alarm-notification-common-6.1.9.jar" crc="60BFA6F5" length="24883"/>
                <jar name="__210612271__alarm-notification-client-6.1.9.jar" crc="E304D305" length="55540"/>
                <jar name="__210612271__alarm-notification-designer-6.1.9.jar" crc="F2FB8E96" length="212432"/>
        </module>
        <module name="com.inductiveautomation.sfc" build="2021080617">
                <jar name="__4116744719__sfc-client-5.1.9.jar" crc="47E2027A" length="143832"/>
                <jar name="__4116744719__sfc-designer-5.1.9.jar" crc="B198F3C5" length="389194"/>
                <jar name="__4116744719__sfc-common-5.1.9.jar" crc="9C264EAF" length="131722"/>
        </module>
        <module name="com.inductiveautomation.opcua" build="2021080617">
                <jar name="__185522049__opc-ua-common-9.1.9.jar" crc="CEDA2BC2" length="2072"/>
                <jar name="__185522049__opc-ua-client-9.1.9.jar" crc="4DA2C609" length="5603"/>
        </module>
        <module name="com.inductiveautomation.eam" build="2021080617">
                <jar name="__1223035611__eam-client-4.1.9.jar" crc="2CF5EA26" length="8512"/>
                <jar name="__1223035611__eam-designer-4.1.9.jar" crc="79A245A" length="43298"/>
                <jar name="__1223035611__eam-common-4.1.9.jar" crc="7CA38074" length="10520"/>
        </module>
        <module name="com.inductiveautomation.sqlbridge" build="2021080617">
                <jar name="__789319690__sql-bridge-designer-10.1.9.jar" crc="E7522CAA" length="888697"/>
                <jar name="__789319690__sql-bridge-common-10.1.9.jar" crc="E22E70D6" length="114159"/>
        </module>
        <module name="com.inductiveautomation.opcua.drivers.dnp3" build="2021080617">
                <jar name="__2230972389__dnp3-client-4.1.9.jar" crc="D0BF6E30" length="4691"/>
                <jar name="__2230972389__dnp3-designer-4.1.9.jar" crc="49923F27" length="2353"/>
                <jar name="__2230972389__dnp3-common-4.1.9.jar" crc="516F6EE9" length="2591"/>
        </module>
        <module name="com.inductiveautomation.serial-support-client" build="2021080617">
                <jar name="__140291102__serial-support-common-6.1.9.jar" crc="8D0A34BE" length="15681"/>
                <jar name="__140291102__jSerialComm-2.6.2.jar" crc="16F610F3" length="469932"/>
                <jar name="__140291102__serial-support-client-6.1.9.jar" crc="F0BEA15A" length="3091"/>
        </module>
        <module name="com.inductiveautomation.opccom" build="2021080617">
                <jar name="__3735570704__opc-classic-client-6.1.9.jar" crc="8846A12A" length="4172"/>
                <jar name="__3735570704__opc-classic-common-6.1.9.jar" crc="F1E75221" length="6294"/>
        </module>
        <module name="com.inductiveautomation.vision" build="2021080617">
                <jar name="__3016055983__vision-common-11.1.9.jar" crc="959D5745" length="12289"/>
                <jar name="__3016055983__vision-designer-11.1.9.jar" crc="9D92F96F" length="2934497"/>
                <jar name="__3016055983__vision-client-11.1.9.jar" crc="30D223E8" length="3186384"/>
        </module>
        <module name="com.inductiveautomation.perspective" build="2021080617">
                <jar name="__4069681641__perspective-common-2.1.9.jar" crc="3A2D2DED" length="329945"/>
                <jar name="__4069681641__perspective-designer-2.1.9.jar" crc="F6AAFF3C" length="2027533"/>
        </module>
        <module name="com.inductiveautomation.reporting" build="2021080617">
                <jar name="__1782017026__icepdf-viewer-6.3.2.jar" crc="9D046453" length="1232244"/>
                <jar name="__1782017026__reporting-common-6.1.9.jar" crc="C785B109" length="3523022"/>
                <jar name="__1782017026__poi-3.14.jar" crc="107E735E" length="2528204"/>
                <jar name="__1782017026__bcprov-ext-jdk15on-1.64.jar" crc="9F55670E" length="4841817"/>
                <jar name="__1782017026__icepdf-core-6.3.2.jar" crc="C56894E2" length="1440836"/>
                <jar name="__1782017026__reporting-client-6.1.9.jar" crc="838553C4" length="2776954"/>
                <jar name="__1782017026__reporting-designer-6.1.9.jar" crc="FC1A95C8" length="939183"/>
        </module>
        <thirdPartyModules md5="1e5534c2e6eb7f09125d2fe1444c9710"/>
        <connect usessl="false" port="8088"/>
</launch>
Claiming id in C:\Users\stefa\.ignition\cache\gw169.254.16.179_8088...
... obtaining lock
... lock obtained.
... claimed id 6
Calculated necessary downloads:
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        </module>
        <thirdPartyModules md5="null"/>
</launch>
Third party Python modules downloaded.
Downloading "http://169.254.16.179:8088/system/translations/"...
Connect successful.
Starting download of 428 bytes
Download successful
Creating classloader with JAR files: [file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-shortcut-3.7.4.jar/0000000069D867D1/jide-shortcut-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-dock-3.7.4.jar/0000000005A8E7A8/jide-dock-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jyiconfonts-3.4.0.jar/00000000D1221784/jyiconfonts-3.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/miglayout-core-4.2.jar/00000000FEECEF57/miglayout-core-4.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-common-1.4.10.jar/00000000269DE677/kotlin-stdlib-common-1.4.10.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-collections4-4.4.jar/000000006847F0D3/commons-collections4-4.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/client-api-8.1.9.jar/000000005BCB639E/client-api-8.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jose4j-0.7.2.jar/000000005975173E/jose4j-0.7.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlinx-coroutines-core-1.4.1.jar/00000000C25969D4/kotlinx-coroutines-core-1.4.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/common.jar/00000000916F97EB/common.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jul-to-slf4j-1.7.26.jar/00000000BF2AD0D0/jul-to-slf4j-1.7.26.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/metrics-core-3.1.0.jar/000000005DDD5FB5/metrics-core-3.1.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/active-query-builder-8.1.9.jar/000000003B9787D2/active-query-builder-8.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-lang3-3.11.jar/000000004FD4C07C/commons-lang3-3.11.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/xmlgraphics-commons-2.3.jar/00000000CAE5A1BA/xmlgraphics-commons-2.3.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/imageio-core-3.4.1.jar/00000000B2745841/imageio-core-3.4.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/poi-ooxml-4.1.1.jar/000000005C3A1400/poi-ooxml-4.1.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/imageio-batik-3.4.1.jar/00000000170253E4/imageio-batik-3.4.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/rhino-1.7.6.jar/000000007D1D24AD/rhino-1.7.6.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-jdk7-1.4.30.jar/000000007E164E98/kotlin-stdlib-jdk7-1.4.30.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-jdk7-1.4.10.jar/00000000DD8F0643/kotlin-stdlib-jdk7-1.4.10.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/common-image-3.4.1.jar/0000000032B2CC13/common-image-3.4.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/rsyntaxtextarea-3.0.0.jar/0000000045FD9024/rsyntaxtextarea-3.0.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jxbrowser-swing-7.12.1.jar/00000000A75EF1E7/jxbrowser-swing-7.12.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/swingx-0.0.3-ia.jar/0000000065E602E1/swingx-0.0.3-ia.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/curvesapi-1.06.jar/00000000D1B9BE33/curvesapi-1.06.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-common-1.4.30.jar/000000000338E948/kotlin-stdlib-common-1.4.30.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-jdk8-1.4.10.jar/000000007A091E89/kotlin-stdlib-jdk8-1.4.10.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/slf4j-api-1.7.26.jar/00000000A71DAC84/slf4j-api-1.7.26.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/bcpkix-jdk15on-1.64.jar/0000000014F43AC5/bcpkix-jdk15on-1.64.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jgrapht-core-1.4.0.jar/00000000AB8E765E/jgrapht-core-1.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-compress-1.19.jar/0000000019AE5191/commons-compress-1.19.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/ia-gson-2.8.5.jar/000000007F980716/ia-gson-2.8.5.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/forms-1.0.7.jar/000000005E8CB029/forms-1.0.7.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/poi-ooxml-schemas-4.1.1.jar/0000000008F7A32A/poi-ooxml-schemas-4.1.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jython-ia-2.7.2.0.jar/000000009694BC85/jython-ia-2.7.2.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-swing-1.12.jar/00000000B83D4C3E/batik-swing-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-1.4.0.jar/00000000585A8BEA/kotlin-stdlib-1.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-common-3.7.4.jar/000000000DC3DB1B/jide-common-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/log4j-over-slf4j-1.7.26.jar/000000005296FF81/log4j-over-slf4j-1.7.26.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/joda-time-2.10.2.jar/00000000EE76ABA0/joda-time-2.10.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-awt-util-1.12.jar/000000004CEB277F/batik-awt-util-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-util-1.12.jar/00000000F09002E9/batik-util-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/logback-classic-1.2.3.jar/000000006407A406/logback-classic-1.2.3.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-script-1.12.jar/0000000073865109/batik-script-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-codec-1.13.jar/000000001F1614BB/commons-codec-1.13.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-math3-3.6.1.jar/000000005D5A24E1/commons-math3-3.6.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jywidgets-3.4.0.jar/00000000BC77AAE5/jywidgets-3.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-bridge-1.12.jar/000000007F6DB498/batik-bridge-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/java-cup-10k.jar/000000003FCB2D3D/java-cup-10k.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/spellchecker-3.0.0.jar/000000007247673D/spellchecker-3.0.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-dialogs-3.7.4.jar/0000000073B908E3/jide-dialogs-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/synthetica-addons-3.4.0.jar/000000007930C92B/synthetica-addons-3.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-logging-1.2.jar/000000003621FD43/commons-logging-1.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-gvt-1.12.jar/00000000083F7136/batik-gvt-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-text-1.9.jar/0000000089FA2468/commons-text-1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/rsyntaxtextarea-3.0.3.jar/00000000FBDF44C1/rsyntaxtextarea-3.0.3.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jxbrowser-7.12.1.jar/000000008B8D0FBE/jxbrowser-7.12.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/common-lang-3.4.1.jar/000000001C5480E4/common-lang-3.4.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jxbrowser-win64-7.12.1.jar/000000007CDBF04A/jxbrowser-win64-7.12.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/poi-4.1.1.jar/000000005964EDEF/poi-4.1.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-css-1.12.jar/00000000CD9AE2F4/batik-css-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlinx-coroutines-swing-1.4.1.jar/00000000B3E62447/kotlinx-coroutines-swing-1.4.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-dom-1.12.jar/00000000E51605CA/batik-dom-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-xml-1.12.jar/0000000010A9F179/batik-xml-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/core-java6-3.2.1.4.jar/00000000B87C35C4/core-java6-3.2.1.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jfreechart-min-1.0.0.jar/00000000DC0AEE96/jfreechart-min-1.0.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-1.4.10.jar/000000001A4591D7/kotlin-stdlib-1.4.10.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/httpcore-4.4.13.jar/000000002FCEAFE7/httpcore-4.4.13.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/httpclient-4.5.13.jar/00000000EC26836C/httpclient-4.5.13.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/miglayout-swing-4.2.jar/00000000DA98AC37/miglayout-swing-4.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/common-io-3.4.1.jar/00000000E7D4BA58/common-io-3.4.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jheaps-0.11.jar/00000000067F79D2/jheaps-0.11.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-io-2.2.jar/0000000011E1D2AE/commons-io-2.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/barcode4j-2.1.jar/000000000B907C79/barcode4j-2.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/annotations-13.0.jar/00000000E6DD8E33/annotations-13.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/xml-apis-1.3.04.jar/000000009F219AB6/xml-apis-1.3.04.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-action-3.7.4.jar/000000004EBE9458/jide-action-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jydocking-3.4.0.jar/00000000AD8BB5BD/jydocking-3.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/logback-core-1.2.3.jar/00000000D9BC8F47/logback-core-1.2.3.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-common-1.4.0.jar/0000000071337547/kotlin-stdlib-common-1.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/xml-apis-ext-1.3.04.jar/0000000087389C28/xml-apis-ext-1.3.04.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-transcoder-1.12.jar/00000000169E104E/batik-transcoder-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/designer-8.1.9.jar/00000000951951B0/designer-8.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-constants-1.12.jar/00000000188FD9CD/batik-constants-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/languagesupport-3.0.0.jar/00000000184F1325/languagesupport-3.0.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-plaf-9-0.0.1.jar/0000000083F57046/jide-plaf-9-0.0.1.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/rstaui-3.0.0.jar/000000007826CD09/rstaui-3.0.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-diff-3.7.4.jar/0000000052C25AB0/jide-diff-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/synthetica-3.4.0.jar/0000000027D0B8E3/synthetica-3.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-parser-1.12.jar/00000000B8AD1229/batik-parser-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-1.4.30.jar/000000003468EBE0/kotlin-stdlib-1.4.30.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-svg-dom-1.12.jar/000000002502C887/batik-svg-dom-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-svggen-1.12.jar/00000000E2CD27B5/batik-svggen-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-grids-3.7.4.jar/00000000141BFEB0/jide-grids-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-ext-1.12.jar/00000000D8C7ED74/batik-ext-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/kotlin-stdlib-jdk8-1.4.30.jar/0000000077F3191D/kotlin-stdlib-jdk8-1.4.30.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/bcprov-jdk15on-1.64.jar/000000006D2976F7/bcprov-jdk15on-1.64.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/commons-cli-1.4.jar/0000000057B55D77/commons-cli-1.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-i18n-1.12.jar/000000000ECB4E1A/batik-i18n-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-components-3.7.4.jar/00000000FD5B5C01/jide-components-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/xmlbeans-3.1.0.jar/0000000087DB6FAA/xmlbeans-3.1.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/ignition-laf-3.1.0-beta8.jar/000000000D3A355F/ignition-laf-3.1.0-beta8.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/xalan-2.7.2.jar/000000008C752A59/xalan-2.7.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/autocomplete-3.0.0.jar/000000005CAC98EB/autocomplete-3.0.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/cron4j-2.2.3.jar/0000000092886B38/cron4j-2.2.3.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jytable-3.4.0.jar/0000000078172F73/jytable-3.4.0.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/guava-23.3-jre.jar/0000000088C8C1B9/guava-23.3-jre.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/batik-anim-1.12.jar/00000000BEF50792/batik-anim-1.12.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/jide-editor-3.7.4.jar/000000005C2C00A9/jide-editor-3.7.4.jar, file:/C:/Users/stefa/.ignition/cache/resources/platform/serializer-2.7.2.jar/00000000EC00A0FF/serializer-2.7.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.symbol-factory/__2310755172__vision-symbol-factory-7.1.9.jar/000000001FCDA1C8/__2310755172__vision-symbol-factory-7.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.alarm-notification/__210612271__alarm-notification-common-6.1.9.jar/0000000060BFA6F5/__210612271__alarm-notification-common-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.alarm-notification/__210612271__alarm-notification-client-6.1.9.jar/00000000E304D305/__210612271__alarm-notification-client-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.alarm-notification/__210612271__alarm-notification-designer-6.1.9.jar/00000000F2FB8E96/__210612271__alarm-notification-designer-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.sfc/__4116744719__sfc-client-5.1.9.jar/0000000047E2027A/__4116744719__sfc-client-5.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.sfc/__4116744719__sfc-designer-5.1.9.jar/00000000B198F3C5/__4116744719__sfc-designer-5.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.sfc/__4116744719__sfc-common-5.1.9.jar/000000009C264EAF/__4116744719__sfc-common-5.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.opcua/__185522049__opc-ua-common-9.1.9.jar/00000000CEDA2BC2/__185522049__opc-ua-common-9.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.opcua/__185522049__opc-ua-client-9.1.9.jar/000000004DA2C609/__185522049__opc-ua-client-9.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.eam/__1223035611__eam-client-4.1.9.jar/000000002CF5EA26/__1223035611__eam-client-4.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.eam/__1223035611__eam-designer-4.1.9.jar/00000000079A245A/__1223035611__eam-designer-4.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.eam/__1223035611__eam-common-4.1.9.jar/000000007CA38074/__1223035611__eam-common-4.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.sqlbridge/__789319690__sql-bridge-designer-10.1.9.jar/00000000E7522CAA/__789319690__sql-bridge-designer-10.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.sqlbridge/__789319690__sql-bridge-common-10.1.9.jar/00000000E22E70D6/__789319690__sql-bridge-common-10.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.opcua.drivers.dnp3/__2230972389__dnp3-client-4.1.9.jar/00000000D0BF6E30/__2230972389__dnp3-client-4.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.opcua.drivers.dnp3/__2230972389__dnp3-designer-4.1.9.jar/0000000049923F27/__2230972389__dnp3-designer-4.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.opcua.drivers.dnp3/__2230972389__dnp3-common-4.1.9.jar/00000000516F6EE9/__2230972389__dnp3-common-4.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.serial-support-client/__140291102__serial-support-common-6.1.9.jar/000000008D0A34BE/__140291102__serial-support-common-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.serial-support-client/__140291102__jSerialComm-2.6.2.jar/0000000016F610F3/__140291102__jSerialComm-2.6.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.serial-support-client/__140291102__serial-support-client-6.1.9.jar/00000000F0BEA15A/__140291102__serial-support-client-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.opccom/__3735570704__opc-classic-client-6.1.9.jar/000000008846A12A/__3735570704__opc-classic-client-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.opccom/__3735570704__opc-classic-common-6.1.9.jar/00000000F1E75221/__3735570704__opc-classic-common-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.vision/__3016055983__vision-common-11.1.9.jar/00000000959D5745/__3016055983__vision-common-11.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.vision/__3016055983__vision-designer-11.1.9.jar/000000009D92F96F/__3016055983__vision-designer-11.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.vision/__3016055983__vision-client-11.1.9.jar/0000000030D223E8/__3016055983__vision-client-11.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.perspective/__4069681641__perspective-common-2.1.9.jar/000000003A2D2DED/__4069681641__perspective-common-2.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.perspective/__4069681641__perspective-designer-2.1.9.jar/00000000F6AAFF3C/__4069681641__perspective-designer-2.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.reporting/__1782017026__icepdf-viewer-6.3.2.jar/000000009D046453/__1782017026__icepdf-viewer-6.3.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.reporting/__1782017026__reporting-common-6.1.9.jar/00000000C785B109/__1782017026__reporting-common-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.reporting/__1782017026__poi-3.14.jar/00000000107E735E/__1782017026__poi-3.14.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.reporting/__1782017026__bcprov-ext-jdk15on-1.64.jar/000000009F55670E/__1782017026__bcprov-ext-jdk15on-1.64.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.reporting/__1782017026__icepdf-core-6.3.2.jar/00000000C56894E2/__1782017026__icepdf-core-6.3.2.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.reporting/__1782017026__reporting-client-6.1.9.jar/00000000838553C4/__1782017026__reporting-client-6.1.9.jar, file:/C:/Users/stefa/.ignition/cache/resources/modules/com.inductiveautomation.reporting/__1782017026__reporting-designer-6.1.9.jar/00000000FC1A95C8/__1782017026__reporting-designer-6.1.9.jar]
Starting class: com.inductiveautomation.ignition.designer.DesignerStartupHook
22:13:19.098 [secure-random-seed-gen] INFO Common.SecureRandomProvider - Secure random seed generated in 0ms
22:13:20.318 [StartupStep-Starter] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Initializing gateway connection with URLs: [http://169.254.16.179:8088]
22:13:20.446 [StartupStep-Starter] INFO com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager - Progress manager started.
Huh, I’ve got no idea why it’s not showing up. Maybe a graphics related issue?
You could try changing false to true for the sun.java2d.d3d in the big command… also try wiping out the entire ~/.ignition/cache directory.
Was hoping there would be an obvious error and it would turn out something like this post.
Another thing I noticed is the first entry in the launch manifest written to your logs has significantly less entries in it than mine… Did anything go wrong with your installation?
nope, tried reinstalling, turned off firewall and windows defender, I have no idea what else to check
When you go to http://169.254.16.179:8088/system/launchmf/D?os=windows&arch=x64 in your browser what do you see?
(what about the other IP I saw in your logs as well?)
I was changing IPs because I thought its a firewall issue or defender.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<launch scope="D" framework="7" jreVersion="11.0.7">
<module name="" build="2020082513">
<jar name="jide-components-3.7.2.jar" crc="D1D1C7CB" length="403622"/>
<jar name="swingx-0.0.1-ia.jar" crc="B6224A42" length="1508604"/>
<jar name="common.jar" crc="4B987712" length="3429202"/>
<jar name="jul-to-slf4j-1.7.26.jar" crc="BF2AD0D0" length="4589"/>
<jar name="metrics-core-3.1.0.jar" crc="5DDD5FB5" length="111908"/>
<jar name="xmlgraphics-commons-2.3.jar" crc="CAE5A1BA" length="671727"/>
<jar name="kotlin-stdlib-common-1.3.71.jar" crc="AC485882" length="179597"/>
<jar name="imageio-core-3.4.1.jar" crc="B2745841" length="72506"/>
<jar name="poi-ooxml-4.1.1.jar" crc="5C3A1400" length="1859884"/>
<jar name="imageio-batik-3.4.1.jar" crc="170253E4" length="19374"/>
<jar name="jyiconfonts-3.0.1.jar" crc="37C7DD76" length="1142728"/>
<jar name="designer-8.0.16.jar" crc="B84F4E6D" length="11979600"/>
<jar name="rhino-1.7.6.jar" crc="7D1D24AD" length="1188593"/>
<jar name="jose4j-0.7.0.jar" crc="193784F1" length="265685"/>
<jar name="common-image-3.4.1.jar" crc="32B2CC13" length="86066"/>
<jar name="rsyntaxtextarea-3.0.0.jar" crc="45FD9024" length="1160826"/>
<jar name="jxbrowser-win64-6.24.jar" crc="378CE234" length="48638953"/>
<jar name="curvesapi-1.06.jar" crc="D1B9BE33" length="111875"/>
<jar name="slf4j-api-1.7.26.jar" crc="A71DAC84" length="41139"/>
<jar name="bcpkix-jdk15on-1.64.jar" crc="14F43AC5" length="878038"/>
<jar name="jgrapht-core-1.4.0.jar" crc="AB8E765E" length="1091677"/>
<jar name="commons-compress-1.19.jar" crc="19AE5191" length="615064"/>
<jar name="ia-gson-2.8.5.jar" crc="7F980716" length="261492"/>
<jar name="forms-1.0.7.jar" crc="5E8CB029" length="86828"/>
<jar name="poi-ooxml-schemas-4.1.1.jar" crc="8F7A32A" length="7884238"/>
<jar name="jywidgets-3.0.1.jar" crc="DD4A42DB" length="512980"/>
<jar name="batik-swing-1.12.jar" crc="B83D4C3E" length="190772"/>
<jar name="jide-common-3.7.4.jar" crc="DC3DB1B" length="1632900"/>
<jar name="kotlin-stdlib-1.3.70.jar" crc="40ABB8A0" length="1379828"/>
<jar name="log4j-over-slf4j-1.7.26.jar" crc="5296FF81" length="23650"/>
<jar name="joda-time-2.10.2.jar" crc="EE76ABA0" length="642711"/>
<jar name="batik-awt-util-1.12.jar" crc="4CEB277F" length="422448"/>
<jar name="batik-util-1.12.jar" crc="F09002E9" length="127209"/>
<jar name="logback-classic-1.1.7.jar" crc="5F8461CE" length="304075"/>
<jar name="commons-lang3-3.9.jar" crc="15449BE" length="503880"/>
<jar name="batik-script-1.12.jar" crc="73865109" length="25715"/>
<jar name="commons-codec-1.13.jar" crc="1F1614BB" length="344339"/>
<jar name="commons-math3-3.6.1.jar" crc="5D5A24E1" length="2213560"/>
<jar name="batik-bridge-1.12.jar" crc="7F6DB498" length="695968"/>
<jar name="java-cup-10k.jar" crc="3FCB2D3D" length="84156"/>
<jar name="spellchecker-3.0.0.jar" crc="7247673D" length="96562"/>
<jar name="jide-dialogs-3.7.4.jar" crc="73B908E3" length="60097"/>
<jar name="httpclient-4.5.11.jar" crc="F53340A4" length="777718"/>
<jar name="client-api-8.0.16.jar" crc="A3594B64" length="2998093"/>
<jar name="kotlin-stdlib-common-1.3.70.jar" crc="4A2FF458" length="179597"/>
<jar name="commons-logging-1.2.jar" crc="3621FD43" length="61829"/>
<jar name="batik-gvt-1.12.jar" crc="83F7136" length="191437"/>
<jar name="rsyntaxtextarea-3.0.3.jar" crc="FBDF44C1" length="1166000"/>
<jar name="common-lang-3.4.1.jar" crc="1C5480E4" length="121090"/>
<jar name="synthetica-addons-3.0.1.jar" crc="C667FCBC" length="295078"/>
<jar name="active-query-builder-8.0.16.jar" crc="5AAEB36F" length="2642316"/>
<jar name="poi-4.1.1.jar" crc="5964EDEF" length="2827712"/>
<jar name="batik-css-1.12.jar" crc="CD9AE2F4" length="325399"/>
<jar name="batik-dom-1.12.jar" crc="E51605CA" length="182590"/>
<jar name="batik-xml-1.12.jar" crc="10A9F179" length="33497"/>
<jar name="core-java6-3.2.1.4.jar" crc="B87C35C4" length="543804"/>
<jar name="jfreechart-min-1.0.0.jar" crc="DC0AEE96" length="1636824"/>
<jar name="httpcore-4.4.13.jar" crc="2FCEAFE7" length="328593"/>
<jar name="jython-2.7.1-ia5.jar" crc="1498F8CC" length="32959175"/>
<jar name="miglayout-swing-4.2.jar" crc="DA98AC37" length="14580"/>
<jar name="common-io-3.4.1.jar" crc="E7D4BA58" length="90843"/>
<jar name="jheaps-0.11.jar" crc="67F79D2" length="133503"/>
<jar name="commons-io-2.2.jar" crc="11E1D2AE" length="173587"/>
<jar name="barcode4j-2.1.jar" crc="B907C79" length="274404"/>
<jar name="jide-grids-3.7.2.jar" crc="CE83B84" length="2322260"/>
<jar name="kotlin-stdlib-1.3.71.jar" crc="B7439E10" length="1379827"/>
<jar name="annotations-13.0.jar" crc="E6DD8E33" length="17536"/>
<jar name="commons-cli-1.2.jar" crc="36D5F961" length="41123"/>
<jar name="xml-apis-1.3.04.jar" crc="9F219AB6" length="194354"/>
<jar name="jide-action-3.7.4.jar" crc="4EBE9458" length="228645"/>
<jar name="jydocking-3.0.1.jar" crc="117218F4" length="321047"/>
<jar name="xml-apis-ext-1.3.04.jar" crc="87389C28" length="85686"/>
<jar name="kotlin-stdlib-jdk8-1.3.71.jar" crc="B1EAEE1D" length="15478"/>
<jar name="batik-transcoder-1.12.jar" crc="169E104E" length="128581"/>
<jar name="kotlinx-coroutines-swing-1.3.5.jar" crc="BF3D1FC3" length="10726"/>
<jar name="batik-constants-1.12.jar" crc="188FD9CD" length="8271"/>
<jar name="languagesupport-3.0.0.jar" crc="184F1325" length="1126022"/>
<jar name="jide-plaf-9-0.0.1.jar" crc="83F57046" length="195573"/>
<jar name="rstaui-3.0.0.jar" crc="7826CD09" length="128884"/>
<jar name="jide-diff-3.7.4.jar" crc="52C25AB0" length="154533"/>
<jar name="batik-parser-1.12.jar" crc="B8AD1229" length="76504"/>
<jar name="batik-svg-dom-1.12.jar" crc="2502C887" length="231948"/>
<jar name="batik-svggen-1.12.jar" crc="E2CD27B5" length="224908"/>
<jar name="batik-ext-1.12.jar" crc="D8C7ED74" length="10075"/>
<jar name="bcprov-jdk15on-1.64.jar" crc="6D2976F7" length="4771726"/>
<jar name="batik-i18n-1.12.jar" crc="ECB4E1A" length="11263"/>
<jar name="xmlbeans-3.1.0.jar" crc="87DB6FAA" length="2579738"/>
<jar name="ignition-laf-3.0.0-beta3.jar" crc="114EDBDC" length="392855"/>
<jar name="xalan-2.7.2.jar" crc="8C752A59" length="3154938"/>
<jar name="autocomplete-3.0.0.jar" crc="5CAC98EB" length="151889"/>
<jar name="cron4j-2.2.3.jar" crc="92886B38" length="36091"/>
<jar name="guava-23.3-jre.jar" crc="88C8C1B9" length="2655564"/>
<jar name="batik-anim-1.12.jar" crc="BEF50792" length="479193"/>
<jar name="kotlin-stdlib-jdk7-1.3.71.jar" crc="CEDB8F4F" length="3129"/>
<jar name="jytable-3.0.1.jar" crc="2EF7243E" length="187406"/>
<jar name="jide-editor-3.7.4.jar" crc="5C2C00A9" length="471792"/>
<jar name="kotlinx-coroutines-core-1.3.5.jar" crc="508EEEA6" length="1559331"/>
<jar name="serializer-2.7.2.jar" crc="EC00A0FF" length="276420"/>
<jar name="jxbrowser-6.24.jar" crc="71C903D9" length="1160694"/>
<jar name="logback-core-1.1.7.jar" crc="1096FB6D" length="470782"/>
<jar name="launchclient.jar" crc="5488E61A" length="4653936"/>
<jar name="synthetica-3.1.1.jar" crc="162B46C0" length="690443"/>
</module>
<module name="com.inductiveautomation.symbol-factory" build="2020082513">
<jar name="__2265400838__vision-symbol-factory-6.0.16.jar" crc="E869D61B" length="35496398"/>
</module>
<module name="com.inductiveautomation.alarm-notification" build="2020082513">
<jar name="__618292654__alarm-notification-client-5.0.16.jar" crc="17266C3E" length="55499"/>
<jar name="__618292654__alarm-notification-common-5.0.16.jar" crc="BF27689C" length="24906"/>
<jar name="__618292654__alarm-notification-designer-5.0.16.jar" crc="82FD9BA1" length="202645"/>
</module>
<module name="com.inductiveautomation.sfc" build="2020082513">
<jar name="__1501841485__sfc-designer-4.0.16.jar" crc="CEC9AAC3" length="384925"/>
<jar name="__1501841485__sfc-client-4.0.16.jar" crc="D1CA1AAA" length="144391"/>
<jar name="__1501841485__sfc-common-4.0.16.jar" crc="AFE5AD86" length="129443"/>
</module>
<module name="com.inductiveautomation.opcua" build="2020082514">
<jar name="__4186071548__opc-ua-common-8.0.16.jar" crc="592781C2" length="1993"/>
<jar name="__4186071548__opc-ua-client-8.0.16.jar" crc="33A2D5DF" length="5561"/>
</module>
<module name="com.inductiveautomation.eam" build="2020082513">
<jar name="__3340291374__eam-client-3.0.16.jar" crc="F0276308" length="8512"/>
<jar name="__3340291374__eam-designer-3.0.16.jar" crc="BBE9C779" length="43704"/>
<jar name="__3340291374__eam-common-3.0.16.jar" crc="EADB6612" length="10462"/>
</module>
<module name="com.inductiveautomation.sqlbridge" build="2020082513">
<jar name="__1250032499__sql-bridge-common-9.0.16.jar" crc="4B0552CD" length="114136"/>
<jar name="__1250032499__sql-bridge-designer-9.0.16.jar" crc="1615DD" length="883263"/>
</module>
<module name="com.inductiveautomation.opcua.drivers.dnp3" build="2020082513">
<jar name="__2935680435__dnp3-client-3.0.16.jar" crc="56856397" length="4691"/>
<jar name="__2935680435__dnp3-designer-3.0.16.jar" crc="1F063297" length="2353"/>
<jar name="__2935680435__dnp3-common-3.0.16.jar" crc="FFF258B3" length="2591"/>
</module>
<module name="com.inductiveautomation.serial-support-client" build="2020082513">
<jar name="__3178309404__jSerialComm-2.5.1-ia2.jar" crc="BCCC014F" length="266110"/>
<jar name="__3178309404__serial-support-common.jar" crc="C5525BE6" length="16044"/>
<jar name="__3178309404__serial-support-client-5.0.16.jar" crc="9DEADCE4" length="3091"/>
</module>
<module name="com.inductiveautomation.opccom" build="2020082513">
<jar name="__2151923216__opc-classic-client-5.0.16.jar" crc="58D09947" length="4172"/>
<jar name="__2151923216__opc-classic-common-5.0.16.jar" crc="E36421D7" length="6231"/>
</module>
<module name="com.inductiveautomation.vision" build="2020082514">
<jar name="__3476330852__vision-designer-10.0.16.jar" crc="353C4497" length="2936855"/>
<jar name="__3476330852__vision-client-10.0.16.jar" crc="679CCA6C" length="3163544"/>
<jar name="__3476330852__vision-common-10.0.16.jar" crc="77D72DC0" length="8788"/>
</module>
<module name="com.inductiveautomation.perspective" build="2020082513">
<jar name="__839062716__jxbrowser-license-6.21.jar" crc="A311E98F" length="585"/>
<jar name="__839062716__perspective-common-1.0.16.jar" crc="8DC642B" length="295959"/>
<jar name="__839062716__perspective-designer-1.0.16.jar" crc="4C05F28A" length="1437168"/>
</module>
<module name="com.inductiveautomation.reporting" build="2020082513">
<jar name="__2754596593__reporting-common-5.0.16.jar" crc="D067E8C4" length="3507765"/>
<jar name="__2754596593__bcprov-ext-jdk15on-1.64.jar" crc="9F55670E" length="4841817"/>
<jar name="__2754596593__poi-3.14.jar" crc="107E735E" length="2528204"/>
<jar name="__2754596593__reporting-designer-5.0.16.jar" crc="741E91EC" length="915324"/>
<jar name="__2754596593__icepdf-core-6.3.2.jar" crc="C56894E2" length="1440836"/>
<jar name="__2754596593__icepdf-viewer-6.3.2.jar" crc="9D046453" length="1232244"/>
<jar name="__2754596593__reporting-client-5.0.16.jar" crc="E6D8401C" length="2776152"/>
</module>
<thirdPartyModules md5="bde9cf4c082948b4060d4df45940b3a9"/>
</launch>
Hmm. Notice how many more jar entries there are in the first module element than in your logs?
And how the jreVersion and build date differs? Something funky is going on with your network or firewall or DNS or something. The contents you just posted are from an older Ignition Gateway.
Aren’t those addresses from APIPA (fallback addressing when no DHCP is present) ?
I uninstalled latest version and installed 8.0.16 because of the project requirements, but still same problem, I think the problem will be that I have also Android Studio installed and different version of java. Does ignition use PATH to java file ? I will also check that
After uninstalling android studio, removing all java files and everything, version 8.0.16
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
</module>
<thirdPartyModules md5="9bdc6b7e85623064e316b39de1975c40"/>
</launch>
Well, I am not sure what happened but I also deleted .Android folders in C:\Users*my name*\ and then started again and I used Windows key + arrows and the windows appeared, but looks like its corrupted or something, btw I have 3 displays, not sure if this could be the issue but finally I could Login to the gateway
I’d like to revive this topic, as I think this is something IA should really look into.
I had this issue happen to me today, where launching the Designer for a Gateway failed.
First, the solution:
I zipped and copied the resources directory located under ~/.ignition/cache from a local PC where I knew both Client[s] and Designer ran without issues. And I mean local, because I was connected through VPN, and that PC was located at the plant where the Gateway is located. Unzipped it on my ~/.ignition/cache directory and I was back in business.
Now the error:
First, the launch_error...log file either reported an error when downloading jide-shortcut-3.7.4.jar or miglayout-core-4.2.jar.
My hypothesis:
I believe this is not an issue with firewalls, antivirus nor defender, but a timeout occurring which must be increased for downloading/transferring all files without issues. Maybe “slow” connections/transfer rates are to blame.
I’ve tried this with Client Launcher for 8.0.9, 8.1.11, and 8.1.17. All failed with similar errors.
If required, I can try to replicate and share any required info.
Thanks!
File: launch_error_2022-06-17_08-31-01.log
Connect Step [attempt 1] connecting to: http://gateway.domain.local:80...
Downloading manifest at http://gateway.domain.local:80/system/launchmf/D?os=windows&arch=x64
<launch scope="D" framework="7" jreVersion="11.0.6">
	<module name="" build="2020060815">
		<jar name="common.jar" crc="F5C9611B" length="3411611"/>
		<jar name="designer-8.0.13.jar" crc="CEAFF706" length="11057327"/>
		<jar name="active-query-builder-8.0.13.jar" crc="3681F538" length="2642316"/>
		<jar name="client-api-8.0.13.jar" crc="53CAC609" length="2997494"/>
		<jar name="launchclient.jar" crc="155BF563" length="3588357"/>
	</module>
	<module name="com.inductiveautomation.symbol-factory" build="2020060815">
		<jar name="__383997794__vision-symbol-factory-6.0.13.jar" crc="39282A30" length="35510772"/>
	</module>
	<module name="com.inductiveautomation.alarm-notification" build="2020060815">
		<jar name="__3529659591__alarm-notification-client-5.0.13.jar" crc="460DF8C3" length="55499"/>
		<jar name="__3529659591__alarm-notification-common-5.0.13.jar" crc="BC65F526" length="24906"/>
		<jar name="__3529659591__alarm-notification-designer-5.0.13.jar" crc="E503FF43" length="202530"/>
	</module>
	<module name="com.inductiveautomation.twilio" build="2020060815">
		<jar name="__1821730563__twilio-client-2.0.13.jar" crc="CE86D020" length="3661"/>
		<jar name="__1821730563__twilio-common-2.0.13.jar" crc="CF3E40E2" length="6130"/>
	</module>
	<module name="com.inductiveautomation.opccom" build="2020060815">
		<jar name="__908110763__opc-classic-client-5.0.13.jar" crc="98BE51F6" length="4172"/>
		<jar name="__908110763__opc-classic-common-5.0.13.jar" crc="10DBDFB6" length="6231"/>
	</module>
	<module name="com.inductiveautomation.vision" build="2020060815">
		<jar name="__2373863458__vision-client-10.0.13.jar" crc="B03105E0" length="3152347"/>
		<jar name="__2373863458__vision-common-10.0.13.jar" crc="2F98F6BC" length="8788"/>
		<jar name="__2373863458__vision-designer-10.0.13.jar" crc="C991D989" length="2931348"/>
	</module>
	<module name="com.inductiveautomation.opcua" build="2020060815">
		<jar name="__1898959478__opc-ua-client-8.0.13.jar" crc="F6F04A9C" length="5561"/>
		<jar name="__1898959478__opc-ua-common-8.0.13.jar" crc="5672B639" length="1993"/>
	</module>
	<module name="com.inductiveautomation.eam" build="2020060815">
		<jar name="__2867375251__eam-client-3.0.13.jar" crc="2395EED5" length="8347"/>
		<jar name="__2867375251__eam-designer-3.0.13.jar" crc="340E5518" length="43716"/>
		<jar name="__2867375251__eam-common-3.0.13.jar" crc="68E47986" length="10462"/>
	</module>
	<module name="com.inductiveautomation.sqlbridge" build="2020060815">
		<jar name="__216760713__sql-bridge-common-9.0.13.jar" crc="AE8A3F57" length="114136"/>
		<jar name="__216760713__sql-bridge-designer-9.0.13.jar" crc="1122B448" length="883255"/>
	</module>
	<module name="com.inductiveautomation.reporting" build="2020060815">
		<jar name="__2056007263__icepdf-core-6.3.2.jar" crc="C56894E2" length="1440836"/>
		<jar name="__2056007263__reporting-common-5.0.13.jar" crc="263C72A9" length="3506322"/>
		<jar name="__2056007263__bcprov-ext-jdk15on-1.64.jar" crc="9F55670E" length="4841817"/>
		<jar name="__2056007263__reporting-designer-5.0.13.jar" crc="676919CD" length="914527"/>
		<jar name="__2056007263__reporting-client-5.0.13.jar" crc="5387493B" length="2776127"/>
		<jar name="__2056007263__poi-3.14.jar" crc="107E735E" length="2528204"/>
		<jar name="__2056007263__icepdf-viewer-6.3.2.jar" crc="9D046453" length="1232244"/>
	</module>
	<thirdPartyModules md5="b195ceceef6e588cdbca0f07422fad6b"/>
	<connect usessl="false" port="80"/>
</launch>
Claiming id in C:\Users\thecesrom\.ignition\cache\gwgateway.domain.local_80...
... obtaining lock
... lock obtained.
... claimed id 0
	</module>
	</module>
	</module>
	</module>
	</module>
	</module>
	</module>
	</module>
	</module>
	</module>
</launch>
Downloading "http://gateway.domain.local:80/system/jar/m/httpclient-4.5.11.jar" (timeout=60000)...
Connect successful.
Download attempt #0 for file httpclient-4.5.11.jar failed.
java.net.SocketException: Unexpected end of file from server
	at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:866)
	at java.base/sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:689)
	at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:863)
	at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1620)
	at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1525)
	at java.base/java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:527)
	at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.downloadJar(DownloadJarsStep.java:139)
	at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:77)
	at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:58)
	at com.inductiveautomation.ignition.client.launch.steps.AbstractLaunchStep.runLockedAction(AbstractLaunchStep.java:95)
	at com.inductiveautomation.ignition.client.launch.steps.BaseStep.runLockedAction(BaseStep.java:21)
	at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.run(DownloadJarsStep.java:55)
	at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33)
	at java.base/java.lang.Thread.run(Thread.java:829)
Connect successful.
Download attempt #1 for file httpclient-4.5.11.jar failed.
Connect successful.
Download attempt #2 for file httpclient-4.5.11.jar failed.
Launch failed on step "DownloadJarsStep" with error:
Since I cleared my ~/.ignition/cache directory, I am trying to add all previous Gateways, and this occurred this morning.
The exception occurs when attempting to download httpclient-4.5.11.jar in this particular case.
Thoughts? Is this a timeout issue?
Thanks,
César
Every case like this I've ever seen come through support has ended up being some kind of network/firewall issue, not a timeout. I know that's inconvenient for you to hear, but that's probably where you need to be looking. Lots of stateful firewalls and network appliances do deep packet inspection and get things wrong when they see zip or JAR files.
