I'm having a strange issue with the SQL Query Browser and the Tag Query editor in the Ignition Designer.
The text editor doesn't respond properly — the cursor position doesn't match the text,
and sometimes clicking or typing happens in the wrong place. It's very hard to edit queries because
the caret and the actual text are out of sync.
I've tried closing and reopening the Designer, and even restarting the Gateway, but the issue persists.
It happens only inside the Query Browser and Tag Query windows; other script editors seem fine.
Has anyone else experienced this behavior?
Could it be related to the rendering mode (hardware vs software), or maybe a Designer cache issue?
I'm running Ignition version [your version number here] on [your OS].
Good. Please hit the "Solution" link under your last post so the question appears as solved in the main index and the solution summary appears below the original question. Thanks!
