I'm getting an NPE attempting to write the x axis span start and end when the x axis is set to time type.
I wouldn't be surprised if this was just due to the time axis not having the same members available as the normal cartesian axis.
Edit: Yeah, that's what it was. Inspecting the output from console log on the context.chart.scales.x shows that time axis does not have start or end.
Version 2.0.1
java.lang.NullPointerException: Element cannot be null
at java.base/java.util.Objects.requireNonNull(Unknown Source)
at com.inductiveautomation.perspective.gateway.property.PropertyTree$ValueNode.(PropertyTree.java:1286)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.nodeFromJson(PropertyTree.java:445)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.nodeFromJson(PropertyTree.java:411)
at com.inductiveautomation.perspective.gateway.property.PropertyTree$ValueNode.write(PropertyTree.java:1349)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.lambda$write$1(PropertyTree.java:543)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.writeImpl(PropertyTree.java:586)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.write(PropertyTree.java:543)
at com.inductiveautomation.perspective.gateway.property.PropertyTree.writeAll(PropertyTree.java:537)
at com.inductiveautomation.perspective.gateway.model.ComponentModel.onPropertySync(ComponentModel.java:557)
at com.inductiveautomation.perspective.gateway.model.ViewModel.lambda$onPropSync$6(ViewModel.java:362)
at com.inductiveautomation.perspective.gateway.model.ComponentModel.dispatch(ComponentModel.java:502)
at com.inductiveautomation.perspective.gateway.model.ComponentModel.dispatch(ComponentModel.java:508)
at com.inductiveautomation.perspective.gateway.model.ViewModel.onPropSync(ViewModel.java:359)
at com.inductiveautomation.perspective.gateway.model.PageModel$Handlers.lambda$onPropSync$29(PageModel.java:1250)
at java.base/java.util.concurrent.CompletableFuture.uniAcceptNow(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.uniAcceptStage(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.thenAccept(Unknown Source)
at com.inductiveautomation.perspective.gateway.model.PageModel$Handlers.lambda$onPropSync$31(PageModel.java:1248)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.lambda$mdcWrap$0(LoggingContext.java:41)
at com.inductiveautomation.ignition.common.util.TimedRunnable.run(TimedRunnable.java:21)
at com.inductiveautomation.ignition.common.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:239)
Page Example
"custom": {},
"params": {},
"props": {},
"root": {
"children": [
"custom": {
"xAxis": {
"end": 73.0968209836805,
"start": -6.903179016319503
"meta": {
"name": "Chartjs"
"position": {
"height": 300,
"width": 633,
"x": 69,
"y": 242
"props": {
"data": {
"datasets": [
"data": [
"x": 0,
"y": 20.790464349448122
"x": 1,
"y": 27.541905413990484
"x": 2,
"y": 9.044548907913263
"x": 3,
"y": 63.58544584440057
"x": 4,
"y": 40.57122042169531
"x": 5,
"y": 46.17945691520222
"x": 6,
"y": 5.272367698783542
"x": 7,
"y": 78.62029735550435
"x": 8,
"y": 1.384758302338518
"x": 9,
"y": 8.094105544748587
"x": 10,
"y": 93.29711393437752
"x": 11,
"y": 78.54999817500953
"x": 12,
"y": 30.022085778849018
"x": 13,
"y": 68.38927062938775
"x": 14,
"y": 93.84973459203651
"x": 15,
"y": 85.15266831524416
"x": 16,
"y": 3.3272574045278946
"x": 17,
"y": 3.4738230710669837
"x": 18,
"y": 76.78237778113568
"x": 19,
"y": 76.13468451530511
"x": 20,
"y": 88.63284915490885
"x": 21,
"y": 92.74877419440537
"x": 22,
"y": 94.12886888152015
"x": 23,
"y": 97.06398992204936
"x": 24,
"y": 46.71625167184086
"x": 25,
"y": 13.224799335767212
"x": 26,
"y": 35.052260048430696
"x": 27,
"y": 29.46821488097423
"x": 28,
"y": 90.27395392440542
"x": 29,
"y": 7.832816289114186
"x": 30,
"y": 15.799390058813623
"x": 31,
"y": 80.66585380750348
"x": 32,
"y": 4.629220116475031
"x": 33,
"y": 24.00958904699422
"x": 34,
"y": 8.133906226255029
"x": 35,
"y": 81.93116748921958
"x": 36,
"y": 82.82333811028309
"x": 37,
"y": 95.37635776015469
"x": 38,
"y": 74.00252644137744
"x": 39,
"y": 27.90694570663671
"x": 40,
"y": 30.569029278167793
"x": 41,
"y": 11.104072480586257
"x": 42,
"y": 68.15581447149303
"x": 43,
"y": 27.051454957054943
"x": 44,
"y": 48.477001171626725
"x": 45,
"y": 73.62917163080661
"x": 46,
"y": 7.528701180738118
"x": 47,
"y": 21.794180888547032
"x": 48,
"y": 17.0019331614802
"x": 49,
"y": 80.4420964468141
"label": "Dataset 1"
"data": [
"x": 25,
"y": 99.00283352088223
"x": 26,
"y": 36.743648170189644
"x": 27,
"y": 33.58269158236888
"x": 28,
"y": 70.52608530981715
"x": 29,
"y": 78.48664561425423
"x": 30,
"y": 99.80258881269653
"x": 31,
"y": 23.56577175483505
"x": 32,
"y": 27.6260054014127
"x": 33,
"y": 11.84780583914382
"x": 34,
"y": 78.95435294680595
"x": 35,
"y": 89.0983947949238
"x": 36,
"y": 87.63589420154018
"x": 37,
"y": 82.4714423791225
"x": 38,
"y": 46.29407127415893
"x": 39,
"y": 12.463880984334686
"x": 40,
"y": 91.82293604614682
"x": 41,
"y": 9.645637547490315
"x": 42,
"y": 23.87358763050218
"x": 43,
"y": 64.35308758482624
"x": 44,
"y": 61.30614039090162
"x": 45,
"y": 60.123113026673906
"x": 46,
"y": 11.262924017594045
"x": 47,
"y": 36.72684549715057
"x": 48,
"y": 19.144808134626057
"x": 49,
"y": 11.499648689135334
"x": 50,
"y": 48.862954644422615
"x": 51,
"y": 44.0188922198424
"x": 52,
"y": 1.4731641405698048
"x": 53,
"y": 76.62654204425371
"x": 54,
"y": 97.09498548555429
"x": 55,
"y": 68.88623969428103
"x": 56,
"y": 9.347347267187478
"x": 57,
"y": 27.59945299037486
"x": 58,
"y": 38.62680310622668
"x": 59,
"y": 64.48467246665813
"x": 60,
"y": 99.50148874944306
"x": 61,
"y": 59.35003045509352
"x": 62,
"y": 7.407803152895475
"x": 63,
"y": 62.077958133975066
"x": 64,
"y": 19.550924069869623
"x": 65,
"y": 59.290461562229346
"x": 66,
"y": 15.46272365498117
"x": 67,
"y": 27.411246578970218
"x": 68,
"y": 59.515203740704415
"x": 69,
"y": 76.39871363134311
"x": 70,
"y": 20.255435491968
"x": 71,
"y": 57.26165130029921
"x": 72,
"y": 73.41996375745644
"x": 73,
"y": 68.57751118650746
"x": 74,
"y": 25.40840081665815
"label": "Dataset 2"
"options": {
"plugins": {
"zoom": {
"pan": {
"modifierKey": null,
"onPan": "(context) \u003d\u003e { \n\nconst xAxis \u003d context.chart.scales.x\nconst customProps \u003d this.store.custom\n\ncustomProps.write(\u0027xAxis.start\u0027, xAxis.start)\ncustomProps.write(\u0027xAxis.end\u0027, xAxis.end)\n}"
"zoom": {
"onZoom": "(context) \u003d\u003e { \n\nconst xAxis \u003d context.chart.scales.x\nconst customProps \u003d this.store.custom\n\ncustomProps.write(\u0027xAxis.start\u0027, xAxis.start)\ncustomProps.write(\u0027xAxis.end\u0027, xAxis.end)\n}"
"scales": {
"x": {
"type": "time"
"y": {
"type": "linear"
"type": "embr.chart.chart-js"
"meta": {
"name": "root"
"type": "ia.container.coord"
