Musson Industrial’s Embr-Charts Module
Yup that’s exactly it. Don’t worry, you’re not the first person to ask about it.
You can still run the same JavaScript using the proxy object, but it does required a gateway round trip before executing.
Maybe a JavaScript button component could come to a 3rd party module near you….
Currently I'm seeing if I can hijack the props.plugins to stuff customizable action buttons onto the canvas. I'm definitely smacking into the difference of just adding some JS to a JS file vs putting it into the Ignition component properties.
I was able to get the example from the docs for plugin defaults to work, but that was simply setting a chart background color.
You “should” be able to copy any examples 1-for-1, assuming they’re using arrow function syntax.
Trying to write JS in a component is pretty crap at the moment. If I had my way, I’d make a custom property type with a custom editor, but there’s no way to do that in SDK.
How are properties not defined in the Add Object Member list inprops.plugins[x] handled, are they just discarded? ie, one of the plugins is configured like
Plugin Property Config
  "events": [
    "mousemove",
    "mouseout",
    "click",
    "touchstart",
    "touchmove"
  "id": "custom_action_buttons",
  "actions": [
      "name": "Reset Zoom",
      "handler": "(context) \u003d\u003e {context.resetZoom();}"
  "afterInit": null,
  "beforeInit": "(chart, args, options) \u003d\u003e {\n\tconst {ctx} \u003d chart;\n\tactions.forEach((a, i) \u003d\u003e {\n\t\t//pass\n\t});\n}"
I get a reference error when trying to access actions so I assume its discarded or just not passed to my beforeInit call.
For context I'm trying to figure out how to get the following JS into a plugin property on the component:
Source JS
const actions = [
    handler(chart) {
      chart.data.datasets.forEach((dataset) => {
        dataset.data = Utils.numbers({
          count: chart.data.labels.length,
          min: -100,
          max: 100
      chart.update();
    name: "Add Dataset",
    handler(chart) {
      const data = chart.data;
      const dsColor = Utils.namedColor(chart.data.datasets.length);
      const newDataset = {
        label: "Dataset " + (data.datasets.length + 1),
        backgroundColor: Utils.transparentize(dsColor, 0.5),
        borderColor: dsColor,
        borderWidth: 1,
        data: Utils.numbers({ count: data.labels.length, min: -100, max: 100 })
      chart.data.datasets.push(newDataset);
      chart.update();
    handler(chart) {
      if (data.datasets.length > 0) {
        data.labels = Utils.months({ count: data.labels.length + 1 });
        for (var index = 0; index < data.datasets.length; ++index) {
          data.datasets[index].data.push(Utils.rand(-100, 100));
        chart.update();
    name: "Remove Dataset",
    handler(chart) {
      chart.data.datasets.pop();
      chart.update();
    handler(chart) {
      chart.data.labels.splice(-1, 1); // remove the label first
        dataset.data.pop();
      chart.update();
actions.forEach((a, i) => {
  let button = document.createElement("button");
  button.id = "button"+i;
  button.innerText = a.name;
  button.onclick = () => a.handler(myChart);
  document.querySelector(".buttons").appendChild(button);
Edit: I know this is absolutely not the intended purpose but I found I can access it by (ab)using the defaults property.
And yes I know the forEach loop technically won't do anything in the component's context, was just trying to see if I can just get the JS in there.
No, all provided properties are transformed (either into functions or CSS variable values) and then passed into the chart.
I haven’t tested, but I imagine you need to put your actions under a key named default in order to access them by options.actions.
From the docs:
Correct, that's exactly what I did to access it. I wonder if adding a specific object key to props.options would also work. :thinking: Edit: Yes you absolutely can.
Fun part now is modifying the source JS code to be able to insert buttons, as the context in the component is different from the context that the example code had access to.
I'm also digging in the legend plugin source code to see how they dedicated a chunk of space on the canvas. They seem to be defining a class, so that might be interesting to try to implement.
If I understand the lifecycle correctly, I'll probably need to define the class in the install event? And maybe stuff it into a key in the context object? I'm not sure how to get it to perpetually exist for the lifetime of the chart.
You’re in uncharted (heh) territory here, I’ve never done anything of the sort. If you find you need functionality that the chart isn’t providing, I’m open to suggestions.
There is an events.beforeRender function you can utilize, but there’s probably a plugin lifecycle step that operates similarly :man_shrugging:
But you shouldn’t need to use a class, classes in JS are wacky.
I'm basically trying to 'build' a plugin for charts.js without actually being able to provide a js file. I don't know if there is a 'safe' way to allow your module to accept custom js files for us to make our own plugins for the chart.
Edit: Advanced style sheet just came to mind for a method to expose the ability for user to provide some JS to the module.
I would argue my use case probably falls under 'extreme edge case'.
I'm definitely running into scope issues(not allowed to perform imports, some of the probably needed methods are unavailable.) Though these might just come down to me crawling the context structure.
Nope, not possible with my module.
Off the top of my head, the “simplest” option I can think of is using WebDev to serve a file which is loaded using HTML injection.
Version 2.0.2 is out, and includes the timestack scale.
Demo View
  "custom": {
    "format": {
      "month": "short"
  "params": {},
  "propConfig": {
    "custom.data": {
      "access": "PRIVATE",
      "binding": {
        "config": {
          "expression": "now(0)"
        "transforms": [
            "code": "\t\t\n\timport random\n\t\t\n\tnow \u003d value\n\tend \u003d system.date.toMillis(now)\n\tstart \u003d system.date.toMillis(system.date.addMonths(now, -1))\n\tsteps \u003d (end - start) / 2048\n\t\n\tpoints \u003d []\n\ty \u003d 50\n\t\n\tmoves \u003d [-1, 1]\n\t\n\tfor ts in range(start, end, steps):\n\t\ty +\u003d random.choice(moves)\n\t\tpoints.append({ \u0027x\u0027: ts, \u0027y\u0027: y })\n\t\t\t\n\treturn points",
            "type": "script"
        "type": "expr"
      "persistent": false
    "custom.format": {
      "persistent": true
  "props": {
    "defaultSize": {
      "height": 477
  "root": {
    "children": [
        "meta": {
          "name": "Chartjs"
        "position": {
          "basis": "300px",
          "grow": 1,
          "shrink": 0
        "propConfig": {
          "props.data.datasets[0].data": {
            "binding": {
              "config": {
                "path": "view.custom.data"
              "type": "property"
          "props.options.scales.x.timestack.format_style.month": {
            "binding": {
              "config": {
                "path": "view.custom.format.month"
              "type": "property"
        "props": {
          "data": {
            "datasets": [
                "label": "Dataset 1"
          "options": {
            "elements": {
              "line": {
                "borderWidth": 1
              "point": {
                "radius": 0
            "parsing": false,
            "plugins": {
              "legend": {
                "display": false
            "scales": {
              "x": {
                "timestack": {
                  "format_style": {}
                "type": "timestack"
              "y": {
                "type": "linear"
          "redraw": true
        "type": "embr.chart.chart-js"
        "children": [
            "events": {
              "component": {
                "onActionPerformed": {
                  "config": {
                    "script": "\tchart \u003d self.parent.parent.getChild(\"Chartjs\")\n\tproxy \u003d chart.getJavaScriptProxy(\u0027chart\u0027)\n\tproxy.runAsync(\u0027\u0027\u0027\n\t\t() \u003d\u003e this.resetZoom()\n\t\u0027\u0027\u0027)\n\t"
                  "scope": "G",
                  "type": "script"
            "meta": {
              "name": "ResetZoom"
            "position": {
              "shrink": 0
            "props": {
              "image": {
                "icon": {
                  "path": "material/zoom_out_map"
              "style": {
                "padding": "0.25rem"
              "text": "Reset Zoom"
            "type": "ia.input.button"
            "children": [
                "meta": {
                  "name": "Label"
                "position": {
                  "shrink": 0
                "props": {
                  "text": "Month Style"
                "type": "ia.display.label"
                "meta": {
                  "name": "Dropdown"
                "position": {
                  "basis": "150px",
                  "shrink": 0
                "propConfig": {
                  "props.value": {
                    "binding": {
                      "config": {
                        "bidirectional": true,
                      "type": "property"
                "props": {
                  "options": [
                      "label": "short",
                      "value": "short"
                      "label": "long",
                      "value": "long"
                      "label": "numeric",
                      "value": "numeric"
                      "label": "2-digit",
                      "value": "2-digit"
                  "style": {
                    "minWidth": "150px"
                "type": "ia.input.dropdown"
            "meta": {
              "name": "MonthStyle"
            "position": {
              "shrink": 0
            "props": {
              "style": {
                "gap": "0.5rem",
                "marginLeft": "auto"
            "type": "ia.container.flex"
        "meta": {
          "name": "Interaction"
        "position": {
          "shrink": 0
        "props": {
          "style": {
            "padding": "0.5rem"
    "meta": {
      "name": "root"
    "props": {
      "direction": "column",
      "style": {
        "gap": "1rem",
How safe (or not safe) is grabbing a javascript proxy from a chart on view load in and stuffing it into parVarMap or similar?
The proxy object holds a reference to the backing Component; I’d be comfortable storing a proxy in a viewVarMap but not in a pageVarMap.
I'm using a proxy object to adjust span/zoom instead of relying on a binding to the component property and the responsiveness is worlds better.
It also means no accidental thrashing from binding/value change script execution order.
Completely unrelated, I can't seem to find/configure the smoothie chart you had previewed a few versions back. Is that a completely separate module?
:heart::tada:
Also worth noting if you talking about storing a proxy object in a pageVarMap:
It’s more correct to think about it as the proxy object. It’s created once on first access, then all other calls to getJavaScriptProxy(name) return the same object over and over again.
It hasn’t been merged yet, I decided I didn’t love the onChartUpdate component method and wanted a more general solution for scheduling tasks inside of Perspective sessions.
But now that I’ve built it (Periscope’s system.perspective.queueSubmit and system.perspective.queueCancel, also not merged) I discovered it doesn’t actually replace the onChartUpdate functionality :joy:.
I can probably post a build including the latest Chart.js components and the beta Smoothie Charts component tomorrow if you’re interested.
How would you go about passing in values of other properties (like custom properties) of the chart component into the inline javascript functions you can define?
I'm guessing there isn't a way to provide additional arguments other than what is provided by the default action you are scripting on.
Edit: trying to abuse a binding to do string concat does not seem to work, as the chart seems to rebuild entirely on a inline function string change.
Wow i'm dumb I can just grab this.store.custom :upside_down_face: :palm_tree:
Yup, you’ve got it. You also have access the global object perspective.context for a quick way at the session, page, and view too (obviously you can transverse to them from the this component reference, but it gets old fast).
Didn't know about this one. I also don't know how I forgot about the this.store I'm using it in about 6 of my scripts already. :person_shrugging:
For anyone using this module,how does it compare to ApexCharts?
I have used both, and found it easier to use. It is technically heavier on the configuration side, but I think it fits the Ignition model well for sandboxiness.
I always felt like ApexCharts were slower for large datasets, but I may not have had to most optimal settings for them. ChartJS just handles a ton of data pretty seamlessly. I can load a few hundred thousand datapoints on a ChartJS and don't feel much lag.
Both have pretty good documentation.
Also, @bmusson has a pretty cool name, but might be biased :man_shrugging:
Disclaimer: I have a lot of experience using ChartJS with normal React applications, and not as much ApexCharts experience so I am sure optimization could have been done for my attempts to implement the ApexCharts.
Thanks, that is useful input!
