Hello!
I work in an injection molding factory, and I would like to set up Ignition to have access to maintenance-related data, since we have nothing of the sort (except production oriented data, of course).
We have around 40 machines, most of which have their own product-handling equipment. So around 80 separate machines, each with their own few plcs of various manufacturers.
I am new to Ignition, and trying to figure out how to build it up. I would like to start with one machine, to be able to see/monitor all its data, to eventually add all systems, so I want to be smart and not give myself trouble further along the way. I’m looking for advice about architecture. Would a single Gateway be enough to manage everything? In said gateway, should I build a different project for each machine? I’m a bit lost in all this! Thank you in advance for your time and help!
Hello, and welcome!
This is a pretty open topic. Just a couple of thoughts... well three... five at most...
Tag structure. Use similar naming /folder structures / UDTs. In my example, we're organized by line number (3425, 3426...). When we need data we pull it by line. Read up in indirect tags, and you'll be a pro.
Document, document, document. Tags, db tables and columns. Perhaps flocharts for operations or data flows. The Useful Tools thread may be of help.
Since you're new to Ignition, I'll suggest going through Inductive University's free training courses.
Use the forum. We have a lot of talented users here, and while we can be pedantic or sometimes downright annoying, we are-- as an old instructor of mine would say-- a veritable cesspool of information.
Hello and thanks for the answer! The Useful Tools thread will be useful, I went to check it out, and I am in the process of getting credentials from Inductive University at the moment, slowly but surely! Thank you for the tips, I will check indirect tagging as well.
I understand the importance of a good structure, either in tags or folders, or anything really! I guess my question was more capabilities/efficiency-related. Should I build each system separately on different gateways, then link gateways through a server? Or could I use a single gateway to build each system as a project? What would be the more efficient way to do it, to avoid trouble when I reach the step of putting the whole thing together? I like the idea of making each system a "project" of its own on one gateway, but would said gateway allow me to build so many projects?
Thanks again!
For only 80 machines all at the same plant, aside from redundancy, I don't see any reason for multiple gateways and projects. Each line or machine can be developed within separate windows within the same project.
