Nightly 8.1 Changelogs - 2022
Weekly Changelog: 8.1.19-b20220628
Enterprise
254: Redundancy: Intermittent Client Recovery Issues when the Master was Active while failed to backup
Clients sometimes failed to execute tag resubscriptions after failover to the other redundant node in a cluster, which could result in stale tags after failover.
2455: Detect duplicate GAN connection when outgoing remote connection already exists
An incoming gateway network connection will no longer be allowed to be established if a separate outgoing gateway network connection to the same remote gateway already exists.
Visualization
5869: Components in a flex container popup do not stretch when resizing the popup
Flex Containers used in Popups will now correctly stretch to fill the popup when the popup is resized.
Connectivity
6150: Create MonitoredItems in Sampling mode before switching to Reporting
Modified monitored item creation so that servers that respond slowly to the CreateMonitoredItems service call don't cause the subscription watchdog timer to elapse.
