Nightly 8.1 Changelogs - 2022
Weekly Changelog: 8.1.19-b20220628
Enterprise
254: Redundancy: Intermittent Client Recovery Issues when the Master was Active while failed to backup
Clients sometimes failed to execute tag resubscriptions after failover to the other redundant node in a cluster, which could result in stale tags after failover.
2455: Detect duplicate GAN connection when outgoing remote connection already exists
An incoming gateway network connection will no longer be allowed to be established if a separate outgoing gateway network connection to the same remote gateway already exists.
Visualization
5869: Components in a flex container popup do not stretch when resizing the popup
Flex Containers used in Popups will now correctly stretch to fill the popup when the popup is resized.
Connectivity
6150: Create MonitoredItems in Sampling mode before switching to Reporting
Modified monitored item creation so that servers that respond slowly to the CreateMonitoredItems service call don't cause the subscription watchdog timer to elapse.
Weekly Changelog: 8.1.19-b20220629
Data Model
3173: UDT Definition NodeRank doesn't update after adding UDT Instances
Modified the loggers for Reporting key errors to be less frequent.
6218: Users are able to change directory in which internal historian idb is saved in by adding directory commands to the provider name (IE ..)
Fixed an issue where the internal historian provider would allow invalid slashes as part of the local file name.
Infrastructure
4406: Upgrader doesn't run on zip upgrade and ignition.conf needs an update to version 13
Updates to ignition.conf and the readme for zip installers.
Connectivity
5939: Modbus RTU and RTU over TCP don't handle exception responses correctly
Fixed a bug handling exception responses in Modbus RTU and RTU over TCP drivers.
6246: Update Milo to version 0.6.7
Updated OPC UA SDK (Eclipse Milo) to version 0.6.7.
Security
6256: Vision User Management component buttons disabled when using IdP authentication strategy
Fix the Vision User Management Panel being disabled when using an Identity Provider to log in.
Weekly Changelog: 8.1.19-b20220630
Visualization
986: Add URL property (back to) reporting components
Added the URL property to Reporting components. This allows you to add clickable hyperlinks within the report preview, Vision report viewer, and PDF output reports, including the Perspective report viewer.
5497: Perspective Alarm status table does not apply bound filter on initial load
Alarm tables no longer discard incoming changes to filters when actively performing a polling query.
Weekly Changelog: 8.1.19-b20220701
Connectivity
6035: Stack overflow in RangeOptimizer.kt
Fixed a possible StackOverflowError during request optimization in the FINS drivers.
Platform
3053: Implement code completion for project scripts
Added autocompletion hints for project library scripts.
Visualization
3778: Add UI to script workspace to choose where intellihints are populated from (Gateway vs Designer)
Add the ability to select a scope for autocomplete hints when authoring project scripts.
Security
5527: Implement unactivate method for leased license strategy
When a leased license is unactivated, the gateway will now attempt to invalidate the license session with the leased activation server. This makes the license eligible for immediate re-activation, without requiring manual invalidation, or waiting up to 4 hours for the license session to expire.
6153: Leased Activation - Need to support multiple 8-digit keys and concurrent activation handling
Activating additional leased licenses (8 digit) will now resolve an effective license from all that have been applied, instead of replacing the existing license.
Weekly Changelog: 8.1.20-b20220706
Visualization
2207: Provide property to disable individual tabs
Adds a new property to the tab component tab "disabled", which allows individual tabs to be disabled/enabled.
921: Tag Status Report Tool - Filterable + excel export
See forum post
Enterprise
6064: Redundancy sync often puts MQTT Transmission provider into an infinite cycle of 'Applying full tag set from backup node' on backup gateway
Redundancy sync system has been updated to prevent a potential endless loop of full synchronization attempts from the master node to the backup node.
Weekly Changelog: 8.1.20-b20220712
Connectivity
6121: Secs/Gem Module - Automatically convert integer values in system.secsgem.sendRequest to float if format is float
Fixed an issue where messages containing integers cannot be coerced to a float/double if the expected format is a float/double.
Weekly Changelog: 8.1.20-b20220715
Visualization
6296: "Drag a component into this container" message for a Flex Container is incorrectly placed
Flex Container - Fixed a pre-existing issue where props.alignItems affected the "Drag component into the container" message in the designer and a 8.1.19 regression where props.justify affected that same message.
1501: Report Viewer: Add suggested filename override property
This adds an optional property to the report viewer that allows setting a custom filename for downloaded reports.
Weekly Changelog: 8.1.20-b20220718
Data Model
6344: Non-Perspective gateway-scoped tag writes and edits are being captured in the audit log
Fixed an issue where scripted tag writes / modifications were being audited within gateway event scripts.
Visualization
6353: Revert IGN-2280 and related regression IGN-6296
Rolled back Flex Container changes 2280 and 6296 as they caused issues with existing customer layouts
Weekly Changelog: 8.1.20-b20220719
Data Model
6269: Upgrading from 7.9 -> 8.x is removing quotes from the SQL Statements of Query Tags
Quotes will no longer be removed from from Query Tags when upgrading from 7.9.
Visualization
4129: Inconsistent page alignment issues on Perspective Session details status page
Fixes alignment issues on the perspective session details page.
Connectivity
6305: ExposedTagsNamespace doesn't map good QualityCodes correctly
Fixed a bug in QualityCode-to-StatusCode mapping that resulted in a successful write to Nodes in the Exposed Tags namespace returning a bad StatusCode.
Enterprise
6131: Queries stuck in DB connection pool, if GAN connection is reset while the query was running
Fixed an issue where tag history database queries made over a remote gateway network connection could become stuck forever if the gateway network connection disconnected and reconnected while processing the query.
Data Model
3807: Uncaught Exception reading historyProvider, timestamp, scanclass property of legacy remote provider
Fixed an issue where an uncaught exception would be thrown when attempting to read the following properties from a v7 remote provider tag: historyProvider, timestamp, scanclass.
3494: Expression tags: isAlarmActive does not reevaluate on change when Execution Mode is Event Driven
Fixed an issue where the isAlarmActive and isAlarmActiveFiltered expressions functions were not automatically re-evaluating when using Event Driven execution mode.
Weekly Changelog: 8.1.20-b20220721 (amended)
Connectivity
2973: Modbus RTU and RTU over TCP tags show good quality despite bad CRC
Fixed Modbus RTU driver not failing on responses with bad CRC.
6313: Modbus RTU: Incomplete message data isn’t cleared from memory causing subsequent received messages and tag data to be corrupt.
Reset the serial connection after an incomplete or timed out response.
6265: Modbus RTU driver no longer requires the Serial Gateway module to function
Modbus RTU driver no longer requires the Serial Support Gateway module.
Data Model
6216: Copy/Pasting Alarm on Tag Doesn’t Allow for Saving Changes
Fixed the Designer Tag Editor updating its "Apply" state after pasting an alarm.
6314: Importing Tag Groups can allow duplicates of the same Group Name
Added a task to migrate tag groups records without a ProviderId to existing tag providers to prevent erroneous changes to records during a tag group import.
6315: Importing Tag Group with Overwrite will take over records with null ProviderId
Platform
6255: Module documentation servlet not setting a content type header
The documentation page provided by a module will now display actual HTML instead of HTML-like text.
Visualization
5764: Vision: "Indigo" named color code doesn't work for expression bindings
Fixed: "Indigo", "IndianRed" will now work with expression bindings. Additionally "MediumPurple" has been corrected from #9370D8 to #9370DB, and "PaleVioletRed" from #D87093 to #DB7093
1967: Ignition and Perspective Co-Branding
Added the co-branding feature to Perspective projects. Forum post coming soon!
Data Model
3862:value format outputted by system.tag.getConfiguration for dateTime tags isn't accepted by system.tag.Configure
system.tag.configure will now correctly handle Datasets and Time values when configuration came from system.tag.getConfiguration.
3926: Historical Tag Provider allows duplicate naming
Adding a datasource no longer creates a corresponding datasource historical provider if a historical provider already exists with an exact name. Furthermore, creating multiple historical providers with the same name is no longer possible.
Weekly Changelog: 8.1.20-b20220725
Connectivity
6244: Programmable Device Simulator random() function error handling
Programmable Device Simulator enforces Min value is less than Max value when using the random() function.
Visualization
5944: Regression in being able to press TAB to cycle through various Perspective Input type components
Fix keyboard tab navigation behavior of dropdown and numeric entry field components. Includes many more improvements to dropdown component interactions and behavior.
Weekly Changelog: 8.1.20-b20220726
Enterprise
3927: Gateway Network: Gateways with same name/UUID can be connected to same GAN without error/warning
Now checking if a new outgoing gateway network connection has the same gateway name or system UUID of any other outgoing gateway network connection. The new connection will be faulted as a duplicate if this situation is encountered.
Visualization
6324: EAM links from Status pages no longer go to the right pages
EAM config links on the status pages fixed to navigate to the correct pages.
5416: setBorderPainted property no longer exposed, but still able to be called, causes invisible buttons
In projects created with Ignition versions prior to 8.1.8, if you set setBorderPainted to false for buttons, you can now open those projects in versions 8.1.8 and greater and the background color for buttons will be correctly displayed.
Connectivity
6078: Logix device OPC tag writes fail with "Bad_NotWritable" even when the External Access property is set to Read/Write
Fixed an issue where Logix writes could sometimes fail if it occurs immediately after a re-browse.
6365: Exposed Tags: set SourceTimestamp from QualifiedValue timestamp in SubscribedTagValue
Set source timestamp of MonitoredItems targeting exposed tags using the underlying timestamp from the TagChangeEvent.
Weekly Changelog: 8.1.20-b20220727
Data Model
6303: Ability to have binary string/byte data in dataset tags
Allow storing byte arrays in Datasets.
6335: UDT Parameters button is missing from Alarm Expression editor after Tag Editor rewrite
The UDT parameter reference button has been replaced for the UDT member Alarm expression editor.
Connectivity
3937: system.opc.browseServer getServerNodeId/getNodeId
An OPCBrowseElement’s server node ID can now be obtained using the getNodeId method.
Visualization
1386: Perspective component paste context menu should be broken into two: paste and paste-replace
Added paste-replace operation in Perspective.
Weekly Changelog: 8.1.20-b20220728
Data Model
6055: Interactive import for UDTs doesn't handle tag EXTENSION type correctly when importing UDTs from 7.9
Support missing tag types in Interactive Importer when importing UDTs from a 7.9 export.
4966: Unable to acknowledge alarm due to multiple eventIDs being generated
Fixed a race condition that would result in an orphaned alarm event existing in the state model despite already transitioning to a finished state.
Visualization
4775: Add an error message to the Project Template dropdown on the Create Project screen
A warning symbol is now shown in the "Project Template" comboBox with a tooltip of "Unable to retrieve project templates, please check your internet connection." when there is no internet connection.
6352: Component Error is thrown in Report Viewer component when saving changes in Designer
Stop ReportViewer and PdfViewer components from erroring upon save within the Designer due to redundant pdf service workers, fixes regression introduced in 8.1.18.
3108: Opening a project from within the Designer allows multiple project dialogs
The Project Dialog is now modal, if you press the "Import Project" in the dialog, the File Chooser Dialog that opens is now also modal. This means that those dialogs will now always be on top of the Designer. You can now also close the Project Dialog by pressing the Escape key.
Weekly Changelog: 8.1.20-b20220729
Visualization
6120: Designers show an inaccurate number of concurrent users after a Designer session disconnects and reconnects
Fixed the Designer concurrent users resource view on session reconnect after being disconnected for an extended period of time
Weekly Changelog: 8.1.20-b20220802
Infrastructure
6021: In automated commissioning, changes to license key or activation token env vars don't force an update of the leased activation JSON
Changes to environment variables IGNITION_LICENSE_KEY and IGNITION_ACTIVATION_TOKEN, when supplied, will now update the leased activation license config after initial commissioning. Previously, they would only be absorbed if an existing leased activation configuration was not present.
Data Model
5599: System tags for devices lose their configurations when the device connections are enabled or disabled on the Gateway
Don't remove/add device system tags when a device is edited unless required because of a name change.
Weekly Changelog: 8.1.20-b20220805
Data Model
6360: UDT Definition members are lost on upgrade from 7.9 due to wrong folderid
Prevent UDT Definition members from getting lost on upgrade from 7.9 when those members were added to an inherited folder.
Visualization
6425: Vision: Multiline Strings cause portions of script to disappear from Extension Functions
Fixed an issue where multiline strings would be erroneously removed from Vision component extension functions.
Weekly Changelog: 8.1.20-b20220808
Platform
6196: Add New Tag History Vision Client Permission
Added a new Vision permission "Tag History" that allows restricting tag history functionality on a per-role basis. Existing 8.x projects will see this permission enabled on upgrade--new projects will have it disabled (like the other existing Vision permissions). Users are encouraged to leverage this role to control access to tag history query, calculation, and annotation features from Vision Client.
Weekly Changelog: 8.1.20-b20220810
Enterprise
6367: Gateway network route to redundant master no longer usable after redundancy config changes
Redundant remote gateways that were changed to independent gateways then changed back into redundant masters/backups would not reconnect properly over the gateway network until the local gateway was restarted.
