Nightly 8.1 Changelogs - 2024
Nightly Changelog: 8.1.40-SNAPSHOT-b20240424
Swing
Designer
IGN-9571: Deleting a Vision component using delete key on keyboard causes previously selected tag in tag browser to be deleted
Fixed an issue where after resetting panels, manipulating [cut,copy,paste,delete] a component in Vision or Perspective would incorrectly perform the manipulation for your previously selected tag instead
IGN-7695: Designer: Deleting a block within an alarm pipeline / SFC deletes the entire pipeline / SFC
Fixed an issue where after resetting panels, manipulating [cut,copy,paste,delete] an element in the Alarm NotificationPipelines would incorrectly perform the manipulation for your previously selected tag or pipeline instead
Alarming
Alarm Status
IGN-7803: When an alarm is in a Clear state, bound alarm properties do not update in the Tag Browser or Tag Bindings
Fixed an issue where alarm events weren't updating their "DisplayPath" and "DisplayPathOrSource" property when an alarm initializes or is re-enabled into a clear state.
IGN-9393: Remote alarm queries fail due to unhandled DocumentArray conversion
Fixed an issue which prevented gateways prior to 8.1.31 from retrieving remote alarm events from 8.1.31+ gateways if alarms contained Document type associated data.
Alarm Notification
IGN-7380: VOIP Connections should not stay connected when Gateway is in a Backup status
Added redundancy logic to VOIP Notification Profiles to only activate profiles for active redundant nodes
Platform Core
Licensing
IGN-9141: Update Edge Trial Mode to Support Unlimited Device/OPC Connections
Removed device and OPC client connection limit when running Edge in trial mode.
Perspective
Perspective
IGN-6009: Unicode text displaying incorrectly when in an embedded view within the Designer
Fixed an issue that caused Unicode characters to display incorrectly when in an Embedded View within the Designer.
