Nightly Changelog: 8.0.0-beta.20181115-0221
Here is a partial list of changes that have been incorporated in the last few night’s releases (since build version b2018111202).
Platform - Gateway
11456: Upgraded Jython to 2.7.1 to address import fixes and more
11404: Additional fixes to Tags gateway status page to improve accuracy of tag system status
11383 Improved handling of various folder conditions during tag conversion
11404: Fixed bug of tag groups not appearing on gw status page.
Also fixes provider log tab to only display logs from the specified provider, as well as adding MDC tagging to TagProvider log messages.
Improvements in how tag property editing works/support editing alarm properties across multiple tags
Platform - Designer
10906: Added “Trial Expired” overlay to components with OPC bindings when trial is expired
Alarm Notification
11512 Fixed alarm definition import containing properties from the alarm notification module
Perspective
11035: XY Chart Fails To Display Tag History
XY Chart wasn’t able to parse certain date strings. Added inputFormat to axes prop to allow user to specify their own date formats if XY Chart isn’t able to parse. Set default date format to match date format from tag history. Updated JSON schema to reduce duplication of axis.
10763: Fixed infinite swapping between two views when multiselecting
11252: Perspective works in Chrome on iOS devices
11570: Fix issue of perspective components such as menu tree missing css in some conditions.
Misc
11343: Upgrader v12 tweaks and improvements
Remove deprecated flags on v12 upgrade & fix line endings in startup scripts
