Perspective Toggles the pipe draw tool
Hello Everyone,
I am trying to display a pipe on top of the template in Ignition perspective.
I need to show a pipe exactly over a template (any other component) (as shown in the attached image). I tried changing the direction (forward/backward) and also adjusting the Z-order, but it is not working as expected. The pipe is still not appearing on top.
Could you please suggest the correct way to achieve this?
  • Is there a specific setting for the pipe draw tool?
Any guidance or example would be really helpful.
Thanks in advance.
Thank you! Ironically I had a coordinate container used as an overlay already and i tried to condense the layers but just applying it one layer which caused this. I will go back to how I had it.
