Reporting - Can you add value labels on a timeseries chart, on each samples?
I am also interested in knowing if individual points can be labeled, or if vertical lines can be dropped onto the chart at specific timestamps. This would be huge for data visualization.
Available in Vision for many years now, and recently for Reporting, but I haven't seen anything for Perspective.
wow thanks, but for existing ignition reporting components its not possible as of now right?
No.
Found a way doing this with a trick by adding a new pen with a style of bar with no shadow, then adjust the color to 0 opacity of that pen and enable the labels option.
And it will show the sample with line and value label on it! ignition is full of tricks haha
