Reset trial time
Hello,
Is there a way to set the Trial Mode time to zero ?
When the trial mode expires, logging back into the gateway from a web browser is all that is required to reset the time.
@justinedwards.jle I thnk the OP is asking how to make it zero, not reset it from zero.
See this thread:
thank you @Matrix_Engineering
From what I tested it is possible to set the DEMOTIMEREMAINING in the SysProps table to a certain value < 7200 . To be effective, the gateway needs to be restarted. However, it seems not possible to keep the modified value in memory : when the trial mode time goes to 0 the gateway goes for an other 2 hours trial.
