Rockwell SoftLogix 5800
I'm trying to connect to a local instance of SoftLogix 5800 version 20. From what I gather here, this should be possible with the Ignition OPC-UA Server with versions prior to V21 using the older legacy driver. However, while I can browse for tags with the quick client, when I try to read a tag I get the result:
[Bad_ShelvingTimeOutOfRange] The shelving time not within an acceptable range.
Not exactly sure what this even means. Any help would be appreciated.
That one generally means your trial has expired. Just reset it from the gateway web interface.
