SAML Security grants not visible
Hi, I can “Test Login” my SAML Identity provider, and it returns a username and ID correctly.
In Security>Levels, I have authenticated roles Administrator and User setup.
Security Level Grants after testing login is Public>Authenticated, nothing else.
enticated.
Under Roles, it’s empty.
How do I properly configure the roles here?
Do you have roles mapped/configured to the user you are testing the login with for that Idp?
There is more information here in regards to Security Level Rules: Security Level Rules | Ignition User Manual
The boxes are grayed out when I manually added a User to the IDP.
I already have Administrator and User setup under Public>Authenticated>Roles>Administrator|User.
But I still can’t see the “Rules” textbox that this user manual page has.
Update: I added a new rule directly under Authenticated, instead of iteratively under Authenticaed>Roles, and it is now showing up under Security Levels for SAML.
It was confusing me earlier, as I thought that the items under Role would inherit from Authenticated and show up. Fixed now.
