[SOLVED] Designer "Launch client jar Invalid" error on Ubuntu
hello, i'm new using Ignition
First i install the gateway , then designer and finally try to lauch one but I encounter this error
imagen
don't know what happend
I'm using ubuntu and java 17
thank for the help
Welcome,
What version of Ubuntu?
Ubuntu 23.04
Not officially supported.
Try this workaround:
OGM IT WORKS
i copy the files to /usr/share/applications/ and run gtk-launch designerlauncher.desktop and works!
Thank you so much :')
You can mark this topic as solved, if you so wish, glad you got sorted :slight_smile:
I need to add to this... I was receiving this error also but under different circumstances.. in my case, I had a ver 8.1.31 app up in AWS. On the local computers at the customer site, I had the 1.1.31 versions of the Design Launcher and Vision Client Launcher loaded up and had no problem getting into the applications.
We decided to upgrade Ignition to 8.1.36 a few weeks ago and after installing the 1.1.36 versions of the launchers, started getting the Launch Client Jar Invalid message. But only on the computers at my customers site. On my local dev computer, I had no problem running the 1.1.36 launchers.
Going back to the 1.1.31 version of the launchers on my customers computers allowed us to get in but with a message to upgrade when we tried to launch them.
After some time with IA tech support, we were not able to resolve the error. In the end, the solution was on our end to whitelist the customers computer IP's in their firewall to allow the cert check to be allowed through.
It feels like something was added;/changed/enforced in the client launchers somewhere between 1.1.31 and 1.1.36..
The launcher's own java changed from java 11 to java 17. Probably related.
A few people at my shop had to delete their cache, even after upgrding the launcher.
Jordan, that's typically my 1st step when I get something like this but it didn't help. As soon as the customers IT guys whitelisted the IP's of the computers in their firewall, everything started worked properly.
I had the same error appear, but for a different reason altogether. The designer logs showed the following
Turns out my system time was just incorrect. Synced it and I could use the designer again...
I got the same problem. I noticed the VM had a date and time different than the one on Log register. I synchroniced the date and time of the VM and that worked for me...
This Option worked for me, THANKS
I've got this error “Launch client jar Invalid” too and the solution from 83641 didn't help.
I tried starting the Designer like this:
cd ~/.local/share/applications/app
~/.local/share/applications/runtime/bin/java -jar launcher-designer-linux.jar
and noticed that permissions were missing for ~/.ignition/
So the problem was fixed with this command:
sudo chown -R $USER:$USER ~/.ignition/
Just needed to log in and add that I had the same issue! I use VMs for programming and I 'paused' the VM and then went to work the next day and unpaused it, the system clock didn't get a refresh and thought it was yesterday still. A quick time update and it was fixed!!
