Speed problem in the execution of an action in perspective
Hello, good afternoon
I have a speed problem in the execution of an action in perspective. The version of the company is 8.1.20 so it does not include the filtering property in the tables, therefore I used dop-down boxes for this purpose, but the execution of the command is taking more than 30 seconds, any idea to optimize please.
It'd be nice if you posted your code as text, instead of images, if you want folks to take a look at it and optimize it.
From experience, it's probably going to be significantly faster to construct a list of row indices to delete/keep and 'trim' the input dataset using system.dataset.deleteRows as one operation rather than continually resizing a PyDataset/list of rows. You could also be doing some extra work to 'short circuit' your conditions - as it's written now, you might be checking a row for a foreman/pumper match even if the district match failed, for instance.
Thank you very much, I will work on the basis of what you say.
I will put the initial code here as well.
	selectedDistrict=self.getSibling("Dropdown").custom.SelectedValue
	selectedForemen=self.getSibling("Dropdown_1").custom.SelectedValue
	selectedPumper=self.getSibling("Dropdown_0").custom.SelectedValue
	HeaderList=["Meter","Graph","Type","Time","Meter ID","Status","County","Well ID","Distric","Foreman","Pumper","Valve Control","PID Control","Gas Rate","Gas Today", "Gas Yest","Net Gas","Avg 7","Best 7","Vol Ex Diff","Vol Ex Pct","DP","CPress","CAvg","CDraw","TPress","TAvg","TDraw","SP","Temp","FTT","FTY","RT Order","Demand Poll","Demand Poll Status","Battery","Poll Status","Type_Full","Sales Gas"]
	data = system.dataset.toPyDataSet(value)
	ListFilt = []
	if selectedDistrict != "<All District>" or selectedForemen != "<All Foremen>" or selectedPumper != "<All Pumpers>":
		for row in data:
			DistrictMatch = selectedDistrict == "<All District>" or row ["District"] == selectedDistrict
			ForemenMatch = selectedForemen == "<All Foremen>" or row ["Foreman"] == selectedForemen
			PumperMatch = selectedPumper == "<All Pumpers>" or row ["Pumper"] == selectedPumper
			if DistrictMatch and ForemenMatch and PumperMatch:
				ListFilt.append(row)
		filtered_dataset = system.dataset.toDataSet(HeaderList, ListFilt)
		return filtered_dataset
	return value
I would expect this to execute quicker.
	if any(selectedDistrict != "<All District>",selectedForemen != "<All Foremen>",selectedPumper != "<All Pumpers>"):
		ListFilt = []
		for index,row in enumerate(data):
			DistrictMatch = selectedDistrict in {"<All District>",row ["District"]}
			ForemenMatch = selectedForemen in {"<All Foremen>",row ["Foreman"]}
			PumperMatch = selectedPumper in {"<All Pumpers>",row ["Pumper"]}
			if all(DistrictMatch,ForemenMatch,PumperMatch):
				ListFilt.append(index)
		return system.dataset.deleteRows(data, ListFilt)
	return value
Thank you very much, the code as such performs the reverse process, since it eliminates the rows where the statements are true, but it gives me the idea to re-structure it.
You might find my new where() expression function helpful:
In this case, your transform would look something like this:
where({value},
    ({path.to.District.Dropdown.custom.SelectedValue} != '<All District>' && {path.to.District.Dropdown.custom.SelectedValue} != it()['District']) ||
    ({path.to.Foreman.Dropdown.custom.SelectedValue} != '<All Foremen>' && {path.to.Foreman.Dropdown.custom.SelectedValue} != it()['Foreman']) ||
    ({path.to.Pumper.Dropdown.custom.SelectedValue} != '<All Pumpers>' && {path.to.Pumper.Dropdown.custom.SelectedValue} != it()['Pumper'])
I suspect this will run much faster than any script transform.
