Good morning,
I'm trying to add the suffix in a perspective table column.
Here I just format the number as 0.00
but if I add the % the number gets crazy
Thanks for the help
The table rendering is "smart". If you render 0.37 as % you get 37%.
There's a fix. I'm trying to remember ...
Maybe try something like
#0.00%
Data Type Formatting Reference | Ignition User Manual (inductiveautomation.com)
my default percent format is different than yours
No, the documentation on that page says,
%Multiplies the value by 100 and shows as a percent.
That is the problem. It multiplies by 100.
this example may work fine
Try it. It doesn't.
The table column is "smart"!
Yeah is not working, is "smart" but not enough ![]()
It was so easy to manage with the vision power table! Because now I could manage the data so that it works but if I would like to have in my dataset the exactly data that I expect.
Can you divide by 100 in the SQL query (or whatever generates the data)? Then you will have 0.9692 rendered as 96.92%.
I never understood this. This design baffles me...
Yes I could but is so strange that we have to make this strange trick to add a simple suffix, because now I show the data in a table, but the next time I will have to show it in a label and I have to manipulate it every time.
In any case thanks for the help, if you have other ideas that avoid to manipulate the "real" data I will test them
The number formatting is supposed to be based on
https://docs.oracle.com/en/java/javase/11/docs/api/java.base/java/text/DecimalFormat.html
which is where the × 100 comes from.
The doc states that you can add strings to the format using the ' single quotes but it doesn't work in the table.
Format Transform:
Format Transform Video at Inductive University
Maybe you can use something like this but you would need to bind it.
But it isn't. It is some javascript-based formatting that I can't find the documentation reference to right now. But it clearly isn't DecimalFormat based on this:
output = []
for row in value:
row['pcColumn'] = row['pcColumn'] / 100
output.append(row)
return ouput
Pascal will be along shortly to reduce this code to one line.
I believe it's numeral.js
well... If it's expected then I'll oblige
return [row['pcColumn'] / 100 for row in value]
edit: wait, no, it doesn't do the same thing.
What are we trying to do here ?
edit2: ok we want to keep the full row but divide one value by 100, so:
return [dict(row, **{'pcColumn': row['pcColumn'] / 100}) for row in value]
This is apparently a documented bug, dating back to 2020. No update as to the status however.
Though, I'm not sure I would call it a bug, as it also seems to be expected behavior (at least from the developers perspective)
One other easy way around the problem is to return an extra /100 column from the SQL query and use that in the table while not displaying the raw data which would still be available for other uses.
SELECT
Resa,
Resa / 100 AS ResaPerCent,
@Transistor Yes, I guess I will work in this way, is a good compromise
