Table editable value write back to the dataset tag In perspective
I have a dataset tag, I am binding tag to a table. I want two columns to be editable in that and after editing, dataset value should write back to the same tag.
How can I do this?
Any idea?
Thanks.
https://docs.inductiveautomation.com/display/DOC81/system.dataset.setValue
I have tried with system.dataset.setvalue().
Table data is in json format, so setValue is not working for json data.
I have tried to convert data in dataset or Pydataset like this but it is not working.
ah yes like that it wont work
You will have to create a dataset then from the ‘json’ using header and data like the first example here
https://docs.inductiveautomation.com/display/DOC81/Datasets
I think I may be missing something. Are you directly binding to the tag? If I bind a table’s data to a tag, it stays a BasicDataset.
Yes from tag we can get basic Dataset but I have transform script to convert tag data into json because to make fields editable data should be in json right?
You would if you are modifying the data directly in the table. But, you are binding to a tag, instead.
onEditCellCommit
	newData = system.dataset.setValue(self.props.data, event.row, event.column, event.value)
	system.tag.writeBlocking('[tagProvider]path/to/tag', newData)
But it is giving error
1st arg can't be coerced to com.inductiveautomation.ignition.common.Dataset
Did you bind it without the transform?
Yes, It worked, Thanks a lot.I thought json data is required for editable functionality.
I have one more doubt,
How to Access network drive folder in perspective - Ignition - Inductive Automation Forum
any idea for this?
