Ignition 8.1.10
Running into a weird issue on a new install. When I added a tag history splitter, suddenly my database connections show ‘Demo Expired’ in Config>Tags>History. The splitter itself shows a generic ‘Error’. I don’t see any errors in the logs.
The database connections are all good, and the server itself is fully licensed, all the modules are installed, etc.
Confusingly, I have 4 other gateways with the same configuration to the same databases, but they don’t give errors. Only difference is that they have a slightly different set of modules - the working gateways are IO gateways, while the broken one is a front-end gateway for Vision. Both have Historian module/licensing.
I tried historizing a tag to see if it was just a labelling fluke as discussed here, but historizing a system tag (CPU usage) and plotting it on an easy chart gave me the following error:
Trace
java.lang.Exception: Error running query:
TagHistory(paths=[histprov:System:/tag:Gateway/Performance/CPU Usage], start=Thu Dec 23 14:02:00 EST 2021, end=Thu Dec 23 14:12:59 EST 2021, flags=0)@0ms
On: Window 1.Root Container.Easy Chart
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:311)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing tag history query. Please verify that the connection is available, and that tag history is being stored to it.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runTagHistoryQuery(GatewayInterface.java:780)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runTagHistoryQuery(GatewayInterface.java:748)
at com.inductiveautomation.factorypmi.application.gateway.GwiTagHistoryProvider.query(GwiTagHistoryProvider.java:16)
at com.inductiveautomation.ignition.common.sqltags.history.cache.StandardCacheBucket.loadData(StandardCacheBucket.java:232)
at com.inductiveautomation.ignition.common.sqltags.history.cache.StandardCacheBucket.getData(StandardCacheBucket.java:192)
at com.inductiveautomation.ignition.common.sqltags.history.cache.SubCache$BucketHit.getData(SubCache.java:215)
at com.inductiveautomation.ignition.common.sqltags.history.cache.SubCache.getData(SubCache.java:158)
at com.inductiveautomation.ignition.common.sqltags.history.cache.TagHistoryCache.query(TagHistoryCache.java:273)
at com.inductiveautomation.factorypmi.application.gateway.TagHistoryQuery.execute(TagHistoryQuery.java:34)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.execute(QueryManager.java:668)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:308)
... 1 more
Caused by: java.lang.Exception: Error executing tag history query. Please verify that the connection is available, and that tag history is being stored to it.
at com.inductiveautomation.gateway.tags.history.query.DatasourceHistoryInterface.maybeLoadIds(DatasourceHistoryInterface.java:115)
at com.inductiveautomation.gateway.tags.history.query.DatasourceHistoryInterface.getSystemId(DatasourceHistoryInterface.java:159)
at com.inductiveautomation.gateway.tags.history.query.DatasourceQueryExecutor.initialize(DatasourceQueryExecutor.java:544)
at com.inductiveautomation.ignition.gateway.sqltags.history.query.AggregateHistoryQueryExecutor.initialize(AggregateHistoryQueryExecutor.java:78)
at com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.initLoader(HistoryWriter.java:141)
at com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.execute(HistoryWriter.java:211)
at com.inductiveautomation.ignition.gateway.sqltags.history.TagHistoryManagerImpl.queryHistory(TagHistoryManagerImpl.java:537)
at com.inductiveautomation.ignition.gateway.tags.model.ProjectDefaultTagManagerFacade.queryHistory(ProjectDefaultTagManagerFacade.java:436)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.QueryTagHistory.invoke(QueryTagHistory.java:99)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1626)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:116)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.lang.Thread.run(null)
Ignition v8.1.10 (b2021090812)
Java: Azul Systems, Inc. 11.0.11
Has anyone seen this before/have any suggestions? As a jumping off point, restarting the tag historian module and the gateway had no impact. I also tried unactivating and activating my gateway - no change.
Thanks in advance!
