I download ignition 8.1.28 bu
i have this problem
Have you tried...opening the logs?
And i try to reinstall after deleting inductive automation from program files
I believe this is a known issue. See this post for the solution:
Is there an unescaped backslash in your install-info.txt?
Can you upload a full copy of your wrapper logs and your gateway.xml file? From the screenshot it looks like the port is not getting set but I’m not positive.
Ya if you still want a full copy i will send you
I think a wrapper log could still help. Also, there should be a designerlauncher.log file in your user account. Can you upload that as well?
Are there two gateways running?
No there is not i install it right now i used quick start
What file should i upload
What you mentioned in the previous comment ?
Is the IP address showing in the launcher from the local machine?
What OS are you running?
