Can you test a different region?
Ya
Should i reinstall ignition or change region only
You could just try changing the region and then restart the ignition service.
Ok
I change and i restart but nothing change
I will try my best searshing for the solution i will change more than one region and see date in log file if it is appear or not i wish i fix it
And any time you have new suggestion write it please
Thanks for you effort .
You may want to try restarting the machine as well. Sometimes region changes donât fully take effect until restart.
I repeated several time with several region . But no thing Changed
Can you upload the latest version of the wrapper.log?
wrapper.log (2.8 MB)
I upload the latest version of wrapper.log
Since the gateway seems to be running and accessible, can you try launching the designer again and then if it doesnât connect, try expanding the details in the pop up?
You could also close the launcher, delete the designerlauncher.log file and then try again. That way itâs a fresh log.
Also, just to be sure, is this a brand new installation?
