Trying to get datapoint from dataset binding on custom property
I have a custom prop with a query binding, returns 1 row and 70 columns. In a button event script, I would like to get a value at [0,2], etc.
I attempted to follow advice on this thread: https://forum.inductiveautomation.com/t/bind-text-property-of-vision-label-to-tag-dataset-value/51197
But can't seem to get it to work.
Here is the code:
value = u'{$\.sp_data}[0,3]'
#value = u'{$\.sp_data}'
#system.tag.writeBlocking(['[default]Testing Tags/Demaris/PS01_Setpoint.value'], [value])
print value
Neither of the value= statements returned a value. The print result was simply the value string: {$\.sp_data}[0,3] or {$\.sp_data}.
What am I missing here?
You are confusing the expression syntax for accessing a value in a dataset with the python syntax for accessing data in a dataset.
For python you need to do yourDataset.getValueAt(0,2), or if its a pyDataset, yourDataset[0][2].
You'll also need to fetch the dataset data, right now value is just a string with a value of {$\.sp_data}[0,3]. The proper path to fetch the dataset would look something more like myDataset = event.source.parent.sp_data.
To work correctly then, your script would look something like
myValue = myDataset.getValueAt(0, 2)
system.tag.writeBlocking(['[default]Testing Tags/Demaris/PS01_Setpoint.value'],[myValue])
If you have the script editor open for the event, on the right side near the top you should see a tag icon and an icon that looks like a list above that. If you click that list icon, you can traverse the components in your view to be able to find and reference the component property with your dataset.
Right you are! Those subtle differences between expression and python... :man_facepalming:
I started this script off using the Set Tag Value builder. That's what gave me the value = u'{$\.sp_data}'.
Thank you, Ryan!
