hello everyone.
I have a problem. I use ubuntu 20.4 desktop now. I install Ignition 8.1.19 is normal,but I restart computer,ignition gateway can't run.
I need to enter
./ignition.sh start.
I try the command
sudo ./ignition.sh install
but it return "Must be root to perform this action."
I tried it!!
but it always return "unit Ignition not found."
Use sudo systemctl list-units to review the names in your system. v8.1 uses Ignition-Gateway as the service name, IIRC. (I always override that to plain ignition when I install.) Upper-case versus lower-case matters.
Ignition-Gateway
ignition
I can't find about any ignition message in units list
hello everyone. I think, I find the way. Maybe this not key point,but it normal now.
I install ubuntu language alway use chinese, but I change Install ubuntu language is english.
thx...
