Hello
I'm having an issue with asserting that an instance of my custom Report class is actually an instance of the class. I have a module where I declare a Report and ReportDAO class. In the ReportDAO class I have an update function which takes a Report instance and modifies it, but first I want to assert that the passed report is the correct object type.
simplified:
class Report(object):
uuid = None
def __init__(self, uuid):
self.uuid = uuid or str(uuid_module.uuid1())
class ReportDAO(object):
Data access for Report objects
def update(self, report):
Update a single report record
assert_is_report(report)
# updates go here
The assert_is_report just does an issubclass check under the hood but it is failing when passing a report object. I added a bunch of logging to the update function and get the following log results:
log.info("report.__class__: {}".format(report.__class__))
log.info("type(report): {}".format(type(report)))
log.info("Report: {}".format(Report))
log.info(
"issubclass(type(report), Report): {}".format(
log.info("isinstance(report,Report): {}".format(isinstance(report, Report)))
log.info("type(report) is Report: {}".format(type(report) is Report))
new_report = Report(None, None, None)
log.info("new_report.__class__: {}".format(new_report.__class__))
log.info("type(new_report): {}".format(type(new_report)))
log.info(
"issubclass(type(new_report), Report): {}".format(
log.info(
"isinstance(new_report,Report): {}".format(isinstance(new_report, Report))
log.info("type(new_report) is Report: {}".format(type(new_report) is Report))
why is my report instance that is passed to the update function not being recognised as an instance of Report class?
for additional context, the report instance has been saved to and then retrieved from a list at system.util.getGlobals["reports"], and the saving and retrieving is being done by two different projects, that both import the Report and ReportDAO classes directly
