Unresolved reference: moduleDependencySpecs
Trying to generate a new module with the Gradle build system and ignition-module-tools. But in the build.gradle.kts it gives this error on a completely unmodified generated module in the IDE and when trying to build.
Not sure where to go from here, not very familiar with gradle
Seems that you can just delete that line for now: Creating a .modl file of external Java Drivers code using Gradle in IntelliJ - #11 by PGriffith
Leaving a breadcrumb for this post as well..
Progress on fixing this. See my today's comment on inductiveautomation/ignition-module-tools/issues/49.
The moduleDependencySpecs resolve exception should be fixed now in 0.4.0. I tested this locally after syncing up all the version references between the generator and gradle-module-plugin halves of the monorepo.
