Update Security Level Configuration via Script
I am wondering how I can access updateSecurityLevelsConfig through the SecurityLevelManager interface to programmatically import a new Security Levels tree within a Gateway Script.
Anytime I attempt to import the SecurityLevelConfig, the logger setup I have returns the following: cannot import name SecurityLevelConfig.
Any suggestions?
Here's an example script that attempts to compose a new node tree and add in a new node under the Roles node:
def handleMessage(payload):
	logger = system.util.getLogger('GatewayScriptManager')
	try:
	    from com.inductiveautomation.ignition.gateway import IgnitionGateway
	    from com.inductiveautomation.ignition.gateway.auth.security.level import SecurityLevelManager
	    from com.inductiveautomation.ignition.gateway.auth.security.level import SecurityLevelConfig
	    from com.google.common.collect import ImmutableList
	    def cloneAndModify(children):
	        newChildren = []
	        for child in children:
	            modifiedChild = SecurityLevelConfig(
	                child.getName(),
	                child.getDescription(),
	                cloneAndModify(child.getChildren())
	            newChildren.append(modifiedChild)
	        return newChildren
	    def addTestRole(rootConfigs):
	        updated = []
	        for cfg in rootConfigs:
	            if cfg.getName() == "Authenticated":
	                rolesNode = None
	                rolesIndex = None
	                # Find "Roles"
	                for i, c in enumerate(cfg.getChildren()):
	                    if c.getName() == "Roles":
	                        rolesNode = c
	                        rolesIndex = i
	                        break
	                if rolesNode is None:
	                    raise Exception("Roles node not found in Authenticated hierarchy.")
	                # Build Test Role node
	                testRole = SecurityLevelConfig(
	                    "Test Role",
	                    None,
	                            "SecurityZones",
	                            "Represents the security zones that a user has.",
	                            [SecurityLevelConfig("Default", None, [])]
	                # Rebuild Roles children
	                updatedRolesChildren = cloneAndModify(rolesNode.getChildren())
	                updatedRolesChildren.append(testRole)
	                updatedRolesNode = SecurityLevelConfig(
	                    "Roles",
	                    rolesNode.getDescription(),
	                # Rebuild Authenticated node
	                newAuthenticatedChildren = cloneAndModify(cfg.getChildren())
	                newAuthenticatedChildren[rolesIndex] = updatedRolesNode
	                updatedCfg = SecurityLevelConfig(
	                    cfg.getName(),
	                    cfg.getDescription(),
	            else:
	                    cfg.getName(),
	            updated.append(updatedCfg)
	        return updated
	    # Execute update
	    gw_context = IgnitionGateway.get()
	    sec_mgr = gw_context.getSecurityLevelManager()
	    curr_lvls = sec_mgr.getSecurityLevelsConfig()
	    new_lvls = addTestRole(curr_lvls)
	    sec_mgr.updateSecurityLevelsConfig(ImmutableList.copyOf(new_lvls))
	except Exception as e:
	    logger.info(str(e))
First question, is this code LLM generated?
Next, don't define functions in a message handler or other event scripts. Define all your functions in a project library script, including the message handler logic. Then call your function from the actual message handler event.
Additionally, don't import anything inside of a function, import it at the top of the project library script, outside of any function definition. E.G:
def myMessageHandler(payload):
	# blah blah blah
You might be running into a known issue with scoping/library availability in the event scripts, defining your functions in the project library script resolves this.
I would also recommend adding
except java.lang.Throwable as t:
    logger.warn("Java exception occurred", t)
to your try block to catch any java errors. Your current try block will only catch python exceptions, which do not include Java errors.
Haven't you heard of the AI bubble? Of course!
It's honestly much more efficient to prompt "I want to do x" and have an LLM generate a code block that already knows the interfaces defined in the documentation that I didn't even know existed prior to looking through the Sources breakdown.
Per the guidance, I reformatted the original logic to be a script within the project library and am now calling the script from the Gateway Message Handler via ScriptName.main():
logger = system.util.getLogger('UserManagement')
    try:
        newChildren = []
                child.getName(),
        return newChildren
        logger.info(str(e))
    try:
        updated = []
                rolesNode = None
                rolesIndex = None
                # Find "Roles"
                        rolesNode = c
                        rolesIndex = i
                        break
                    "Test Role",
                    None,
                            "SecurityZones",
                    "Roles",
                    cfg.getName(),
            else:
                    cfg.getName(),
        return updated
        logger.info(str(e))
def main():
    try:
        # Execute update
        logger.info(str(e))
And here's the error being thrown:
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 2, in handleMessage ImportError: Error loading module UserManagement: Traceback (most recent call last): File "", line 3, in ImportError: cannot import name SecurityLevelConfig
at org.python.core.Py.ImportError(Py.java:327)
at com.inductiveautomation.ignition.common.script.ScriptModule.loadModule(ScriptModule.java:79)
at com.inductiveautomation.ignition.common.script.ScriptModule.__findattr_ex__(ScriptModule.java:99)
at org.python.core.PyObject.__getattr__(PyObject.java:957)
at org.python.pycode._pyx66.handleMessage$1(:2)
at org.python.pycode._pyx66.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.ignition.common.script.message.MessageHandlerRunnable.run(MessageHandlerRunnable.java:121)
Caused by: org.python.core.PyException: ImportError: Error loading module UserManagement: Traceback (most recent call last): File "", line 3, in ImportError: cannot import name SecurityLevelConfig
ah, looking closer at the docs, you need
from com.inductiveautomation.ignition.common.auth.security.level import SecurityLevelConfig
You were importing from gateway.auth instead of common.auth, the former doesn't have anything besides SecurityLevelManager
See:
Echoing a valid concern from one of the Ignition developers:
Seems I can't trust an LLM's falsifications anymore. Can you explain?
Regarding library scripts:
The 2nd point is especially important when using system.net.httpClient, where you want to be reusing the same instance as much as possible instead of creating a new one each time you do something.
There are also some legacy scoping issues that you get around by having functions defined in the project library script and calling them from events.
Regarding imports:
Basically, the trade off between locking once for an import when first initializing the project library script vs locking every time the function is called. Someone else might be able to explain it in further detail.
One of the fundamental differences between CPython and Jython is that the latter is fully and truly multi-threaded. Jython has no GIL.
That import always takes a lock doesn't create additional lock contention in CPython because the contention is on CPython's GIL.
Ignition performs auto-importing of project library scripts on first use after a project start or restart (edits). That auto-import is lockless, for huge performance wins under busy event load. (But just the fast path is lockless in v8.3, fixing a longstanding bug.)
This is a huge performance win in Ignition because many, many events firing at high rates will crush that interpreter-wide import lock.
And yet, here you were, up a blind alley with no idea how to proceed...
A vibe-coded SCADA project seems about as "efficient" as it does "maintainable", but that's just my two cents late on this Friday afternoon.
All roads lead to...Ignition forum.
