The Tag Helper does no in any way connect to or retrieve data from the Gateway. It's intended purpose is only to store data in the same shape as a Tag, and also to provide enumerated values which would be used to refer to data types in a manner Ignition would understand.
Our use cases for this Helper usually include simplifying variables within a test file. We'll usually have a page which returns Tag information as part of a JSON object. This leads to patterns like this:
TESTING_TAG_NAME = "sine1"
TESTING_TAG_PROVIDER = "[QAProvider]"
KNOWN_PATH_OF_TAG = "something:provider/deviceName/directory"
# some logic
# building this necessary path is prone to errors
self.page_object.chart_tag_in_power_chart(full_path=self.TESTING_TAG_PROVIDER + self.KNOWN_PATH_OF_TAG + "/" + self.TESTING_TAG_NAME)
# and accessing data from json/dictionary is a hassle
tag_data = self.page_object.get_tag_data_as_json()
assert tag_data["enabled"]
assert tag_data["eng_unit"] == "F"
# and so on
These patterns are repetitive, prone to typos, and require that anyone writing a test in this area have extensive knowledge regarding the keys available within the dictionary.
The Tag.py Helper file allows for something along these lines:
# using
tag = Tag(name="sine1", provider="[QAProvider]", path="something:provider/deviceName/directory")
self.page_object.chart_tag_in_power_chart(tag=tag)
# and accessing
tag = TagHelper.build_tag_from_dictionary(tag_configs=self.page_object.get_tag_data_as_json())
# now, you don't need to know about potential keys, because the class exposes all available attributes of the object.
assert tag.enabled
assert tag.eng_unit == "F"
Encapsulating the attributes in a class/object allows for much better access with less worrying about typos and allows more users to test tags without extensive knowledge of what attributes might be available in a dictionary.
An example we had a long time ago (it was not actually a Tag, but same idea):
tag = self.page_object.get_tag_data_as_json()
assert tag.get("en_unit") != "F"
This assertion would pass even if the associated engineering unit was indeed "F", because the automation engineer has accessed the dictionary with a key which does not exist. The usage would always return None, which is obviously not "F", and therefore is resulting in a false positive. Use of the Tag object (and by extension the TagHelper) helps us avoid these pitfalls.
