Dears,
As you see below I got error message on my running gateway on 8.1.13 as I am trying to upgrade to latest version of SW 8.1.32.
Any advice here.
Regards,
I run the setup file as administrator and I have enough space.
See if there's an installation log.
INFO [IgnitionInstaller ] [2023/09/23 15:38:03]: log location set to C:\Users\invadmin\.ignition\install\install.log
INFO [IgnitionInstaller ] [2023/09/23 15:38:03]: log level set to 'INFO'
INFO [IgnitionInstaller ] [2023/09/23 15:39:11]: Install started in directory C:\Program Files\Inductive Automation\Ignition
INFO [IgnitionInstaller ] [2023/09/23 15:39:11]: 0%: Checking existing gateway's state
INFO [IgnitionInstaller ] [2023/09/23 15:39:12]: 0%: Configuring Install Actions
INFO [IgnitionInstaller ] [2023/09/23 15:39:12]: 0%: Executing Install Actions
INFO [IgnitionInstaller ] [2023/09/23 15:39:12]: 0%: Creating a gateway backup. This may take some time...
INFO [IgnitionInstaller ] [2023/09/23 15:39:13]: 0%: gwcmd missing timeout option, retrying without it
INFO [IgnitionInstaller ] [2023/09/23 15:39:13]: 0%: Creating a gateway backup. This may take some time...
INFO [IgnitionInstaller ] [2023/09/23 15:39:22]: 0%: Gateway backup 'backup_20239231539.gwbk' creation complete
INFO [IgnitionInstaller ] [2023/09/23 15:39:22]: 0%: Stopping Gateway. This may take some time..
INFO [IgnitionInstaller ] [2023/09/23 15:39:39]: 0%: Gateway service stopped and uninstalled
INFO [IgnitionInstaller ] [2023/09/23 15:39:39]: 0%: Starting pre-install modifications
INFO [IgnitionInstaller ] [2023/09/23 15:39:39]: 0%: Deleting 'data/jar-cache'
INFO [IgnitionInstaller ] [2023/09/23 15:39:39]: 0%: Deleting 'lib'
INFO [IgnitionInstaller ] [2023/09/23 15:39:40]: 0%: Retaining 'lib\runtime\jre-win'
INFO [IgnitionInstaller ] [2023/09/23 15:39:41]: 0%: Starting Install Extraction
INFO [IgnitionInstaller ] [2023/09/23 15:39:41]: 0%: IgnitionGateway.exe
WARN [ActionController ] [2023/09/23 15:39:41]: An Error Has Occurred
com.inductiveautomation.ignition.installer.common.actions.InstallAction$HaltInstallException: Unable to extract install into 'C:\Program Files\Inductive Automation\Ignition'
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.actions.install.ExtractInstallZipAction.execute(ExtractInstallZipAction.java:150)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.actions.ActionController.lambda$execute$5(ActionController.java:106)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.actions.ActionController.wrapRunnableAction(ActionController.java:154)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.actions.ActionController.execute(ActionController.java:107)
at com.inductiveautomation.ignition.installer.offline@8.1.32/com.inductiveautomation.ignition.installer.offline.OfflineInstaller.startInstall(OfflineInstaller.java:336)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.ui.graphical.InstallerApplication.lambda$startInstall$9(InstallerApplication.java:351)
at java.base/java.lang.Thread.run(Thread.java:829)
java.nio.file.attribute.UserPrincipalNotFoundException: null
at java.base/sun.nio.fs.WindowsUserPrincipals.lookup(WindowsUserPrincipals.java:147)
at java.base/sun.nio.fs.WindowsFileSystem$LookupService$1.lookupPrincipalByName(WindowsFileSystem.java:244)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.utils.IOUtils.setOwnership(IOUtils.java:478)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.utils.UnzipOperation.chown(UnzipOperation.java:220)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.utils.UnzipOperation.execute(UnzipOperation.java:196)
at com.inductiveautomation.ignition.installer.common@8.1.32/com.inductiveautomation.ignition.installer.common.actions.install.ExtractInstallZipAction.execute(ExtractInstallZipAction.java:147)
INFO [IgnitionInstaller ] [2023/09/23 15:39:41]: 0%: Unable to extract install into 'C:\Program Files\Inductive Automation\Ignition'
INFO [IgnitionInstaller ] [2023/09/23 15:39:45]: 0%: Installer action failure. Performing undo
INFO [IgnitionInstaller ] [2023/09/23 15:39:45]: 0%: Reverting new Ignition files
INFO [IgnitionInstaller ] [2023/09/23 15:39:45]: 0%: Reverting ''
INFO [IgnitionInstaller ] [2023/09/23 15:39:46]: 0%: Reverting 'user-lib'
INFO [IgnitionInstaller ] [2023/09/23 15:39:46]: 0%: Reverting 'user-lib\jdbc-bundled'
INFO [IgnitionInstaller ] [2023/09/23 15:39:46]: -89%: Install file revert complete
INFO [IgnitionInstaller ] [2023/09/23 15:39:46]: -89%: Reverting pre-install modifications
INFO [IgnitionInstaller ] [2023/09/23 15:40:07]: -89%: pre-install modifications reverted
INFO [IgnitionInstaller ] [2023/09/23 15:40:07]: -89%: Starting Gateway. This should only take a moment..
INFO [IgnitionInstaller ] [2023/09/23 15:40:12]: -89%: Gateway service started and installed
INFO [IgnitionInstaller ] [2023/09/23 15:40:12]: -89%: Revert of installer actions complete
How much free space have you got on that drive? This guy found that 6 GB was not enough.
See also,
I have 44 Gb space ,No worries about space.
You might need to open a ticket with IA support.
Thanks for your support, can u guide me how to open ticket.
Look under "Support".
Solution done by Inductive automation support ![]()
Unable to upgrade Ignition from 8.1.13 to 8.1.32 receiving error:
An Error Has Occurred com.inductiveautomation.ignition.installer.common.actions.InstallAction$HaltInstallException: Unable to extract install into 'C:\Program Files\Inductive Automation\Ignition'
The stack trace points to it not being able find the Principal User
This typically occurs because the permissions/owner of the initial installation do not allow the current user to modify the install directory
https://stackoverflow.com/questions/12731277/setting-owner-of-a-file-in-java-ver-7-in-windows-xp-sp2
The initial owner of the Install directory seems to be 5-1-5-21-1056255678-1622950809-1427260136-60794
Modifying this to be invadmin through the Advanced Security settings on the Ignition folder allowed for the Gateway to upgrade successfully
Gateway seems healthy upon starting with all expected configurations
Perspective session also seems to be working as expected
Hi Samer,
Thank you for sharing the solution.
I got the same issue, and your post helped me!
Kind regards,
How did you find the initial owner of the directory?
never mind, i found it!
I’ve been working this same issue. I don’t like the solution of changing the owner of the Ignition folder. The same ownership pattern is seen on multiple gateways: assuming default installation path is used, the Inductive Automation folder is owned by Administrators group and the Ignition folder is owned by the user that ran the original install.
We’re trying to install an upgrade with a different account than ran the original install. It seems to me that if it’s truly an OS permissions issue where my new account doesn’t have access to the Ignition folder, I should be able to surface that with normal file system operations, but I’ve not been able to do that, this “permissions issue” only happens when we’re running the Ignition installer.
I even ran the installer from command-line to turn up logging:
ignition-8.1.52-windows-64-installer.exe --% "unattended=text" "location=D:\Program Files\Inductive Automation\Ignition" "logLevel=trace"
This seems to be where it’s running into trouble
…but we’ve not been able to get down to what system calls are being used inside that method.
So the installer fails and reverts, at the very end tries to copy it’s own log file, %USERPROFILE%\.ignition\install\install.log over to the Ignition root and that fails as well.
