Map marker in perspective
I am new to ignition, i want to use the Map component to place some moving vehicles, i have a lot of vehicles to show and it is time consuming to go and create the map marker for each car, the data source is from API, I did create a UDT for the vehicle and took instance from it for each car, I did some scripting to get the data from the API and put it in each car instance, now i want to put the markers on the map, i want to link the long, lat, and name in the tooltip to show it as a text above the marker
can you please share some detailed steps on how to do so as i dont have a lot of experience with ignition so far,
thanks
Welcome to the forum.
Please post a sample of your data for multiple cars so we know how to transform it. Post formatted data - not a picture of data so we don't have to type it all out again. See Wiki - how to post code on this forum.
here
  "name": "vehicles",
  "tagType": "Folder",
  "tags": [
      "name": "9155 SJR",
      "typeId": "vehicle_1_template",
      "tagType": "UdtInstance",
      "tags": [
          "value": 25.622837,
          "name": "Latitude",
          "tagType": "AtomicTag"
          "value": 49.548363,
          "name": "Longitude",
          "value": "0",
          "name": "Speed",
          "value": "2024-05-12T11:47:09",
          "name": "GPS_date",
          "value": "95545.1",
          "name": "Mileage",
      "name": "5958 XJR",
      "tags": [
          "value": "26",
          "name": "Speed",
          "value": 26.230768,
          "name": "Latitude",
          "value": 49.977375,
          "value": "2024-05-12T11:53:26",
          "name": "GPS_date",
          "value": "103574.89",
          "name": "Mileage",
      "name": "5956 XJR",
      "tags": [
          "value": "28",
          "name": "Speed",
          "value": 25.938225,
          "name": "Latitude",
          "value": "2024-05-12T11:53:23",
          "name": "GPS_date",
          "value": 49.938877,
          "value": "130669.87",
          "name": "Mileage",
I think, a dataset type tag to render the data seems like a straightforward and logical approach. While there are multiple ways to implement this, here's a script that you can use
Paste following binding on marker prop
marker binding
  "type": "expr",
  "config": {
    "expression": "now(60000)"
  "transforms": [
      "code": "\timport copy\n\t# Initialize default Marker JSON\n\tMarker_Dict \u003d {\n\t\t\"name\": \"\",\n\t\t\"properties\": {},\n\t\t\"enabled\": True,\n\t\t\"lat\": None,\n\t\t\"lng\": None,\n\t\t\"opacity\": 1,\n\t\t\"icon\": {\n\t\t\"path\": \"material/location_on\",\n\t\t\"color\": \"#4190F7\",\n\t\t\"rotate\": 0,\n\t\t\"size\": {\n\t\t  \"width\": 36,\n\t\t  \"height\": 36\n\t\t},\n\t\t\"style\": {\n\t\t  \"classes\": \"\"\n\t\t}\n\t\t},\n\t\t\"event\": {\n\t\t\"stopPropagation\": False\n\t\t},\n\t\t\"tooltip\": {\n\t\t\"content\": {\n\t\t  \"text\": \"\",\n\t\t  \"view\": {\n\t\t    \"path\": \"\",\n\t\t    \"params\": {}\n\t\t  }\n\t\t},\n\t\t\"direction\": \"auto\",\n\t\t\"permanent\": False,\n\t\t\"sticky\": False,\n\t\t\"opacity\": 1\n\t\t},\n\t\t\"popup\": {\n\t\t\"enabled\": False,\n\t\t\"content\": {\n\t\t  \"text\": \"\",\n\t\t  \"view\": {\n\t\t    \"path\": \"\",\n\t\t    \"params\": {}\n\t\t  }\n\t\t},\n\t\t\"width\": {\n\t\t  \"max\": 300,\n\t\t  \"min\": 50\n\t\t},\n\t\t\"height\": {\n\t\t  \"max\": None\n\t\t},\n\t\t\"pan\": {\n\t\t  \"auto\": True\n\t\t},\n\t\t\"closeButton\": True,\n\t\t\"autoClose\": True,\n\t\t\"closeOnEscapeKey\": True,\n\t\t\"closeOnClick\": None\n\t\t}\n\t}\n\t\n\t# Read all the tags\n\tresults \u003d system.tag.browse(path \u003d \u0027[default]vehicles\u0027)\n\ttagPaths \u003d []\n\tfor result in results.getResults():\n\t\ttagPaths.append(str(result[\"fullPath\"]))\n\tvalues \u003d system.tag.readBlocking(tagPaths)\n\tvehicles \u003d []\n\tfor i in range(len(values)):\n\t\tvehicle_name \u003d tagPaths[i].split(\"/\")[1]\n\t\tvehicle_details \u003d values[i].value\n\t\tvehicles.append({vehicle_name:vehicle_details})\n\t# Add the custom marker instances\n\tMarker_Instances \u003d []\n\tfor vehicle in vehicles:\n\t\tname \u003d vehicle.keys()[0]\n\t\tMarker \u003d copy.deepcopy(Marker_Dict)\n\t\tMarker[\"lat\"] \u003d vehicle[name][\"Latitude\"]\n\t\tMarker[\"lng\"] \u003d vehicle[name][\"Longitude\"]\n\t\tMarker[\"tooltip\"][\"content\"][\"text\"] \u003d name\n\t\tMarker_Instances.append(Marker)\n\treturn Marker_Instances",
      "type": "script"
can you clarify more on this part , and how to do it in your opinion,
You are using a UDT to encapsulate all the data from a vehicle. Suggestion I have is to consolidate all the vehicles data within a dataset type tag, like the example below:
Then you can use the tag as follow.
I think it will be straightforward to build marker instances by iterating a dataset
thanks,
will try it
I've never used the Map component but was interested in your question. Try this:
Map markers 1
Figure 1.
  1. Create two custom properties on the Map component:
  • vehicleStatus and create a binding on this to your GPS data tags that you posted above.
  • sampleMarker. Create the property and paste in a sample marker or the one below.
sampleMarker
  "name": "marker0",
  "properties": {},
  "enabled": true,
  "lat": 25.938225,
  "lng": 49.938877,
  "opacity": 1,
  "icon": {
    "path": "material/location_on",
    "color": "#4190F7",
    "rotate": 0,
    "size": {
      "width": 36,
      "height": 36
    "style": {
      "classes": ""
  "event": {
    "stopPropagation": false
  "tooltip": {
    "content": {
      "text": "Vehicle ID",
      "view": {
        "path": "",
        "params": {}
    "direction": "auto",
    "permanent": false,
    "sticky": false,
    "opacity": 1
  "popup": {
    "enabled": false,
    "content": {
      "text": "",
      "view": {
        "path": "",
        "params": {}
    "width": {
      "max": 300,
      "min": 50
    "height": {
      "max": null
    "pan": {
      "auto": true
    "closeButton": true,
    "autoClose": true,
    "closeOnEscapeKey": true,
    "closeOnClick": null
  1. Create a property binding on ui.marker as shown below.
    Map markers 2
Figure 2.
  1. Paste in the following code:
ui.marker binding script transform
	def recursiveCopy(original):
		# With credit to https://forum.inductiveautomation.com/u/lrose
		# https://forum.inductiveautomation.com/t/copy-dictionary-and-modify-it-without-affecting-the-original/62297/9
	    from copy import deepcopy
	    from com.inductiveautomation.ignition.common.script.abc import AbstractMutableJythonMap,AbstractMutableJythonSequence
	    if isinstance(original,AbstractMutableJythonMap):
	        return {key:recursiveCopy(value) for key,value in original.iteritems()}
	    if isinstance(original,AbstractMutableJythonSequence):
	        return [recursiveCopy(item) for item in original]
	    return deepcopy(original)
	markers = []
	for car in value['tags']:
		protoMarker = recursiveCopy(self.custom.sampleMarker)
		name = car['name']
		for dic in car['tags']:
			if dic['name'] == 'Latitude':
				lat = dic['value']
			if dic['name'] == 'Longitude':
				lng = dic['value']
		protoMarker['lat'] = lat
		protoMarker['lng'] = lng
		protoMarker['tooltip']['content']['text'] = name
		markers.append(protoMarker)
	return markers
How it works:
  • The initial binding brings in this.custom.vehicleStatus. That gets passed to the script transform as value.
  • We read in self.custom.sampleMarker as a template for constructing the list of markers. Due to the way Jython works we need to make a deepcopy of it (otherwise all the markers will be set to the last value). See the article referenced in the script to understand more.
  • Loop through your GPS data and find the name, lat and lng of each vehicle. Note that dictionaries are unordered so we need a loop. Since your data will be short a simple loop is adequate and readable.
  • Update the copy of the template and add it to the list of markers.
I suggest you to store vehicle information on a database then retrieve locations of the vehicle from the database via binding in to UI> Maker.
You can find the latest updated location of the vehicle via the database.
Thanks, I following instructions, I don´t understand where to past this after creating custom sampleMarker property, the only way I can do it is adding each value or object one by one
Map sample marker
Figure 3.
So to use this method with a simplified json as:
    {"name": "05-RIO-MENDA", "latitude": 42.472783, "longitude": -2.40938},
    {"name": "05-NAV-CORDO", "latitude": 42.789632, "longitude": -1.639813},
    {"name": "05-CAL-FORJA", "latitude": 41.624986, "longitude": -4.735528},
    {"name": "05-CAL-RINCO", "latitude": 40.96796, "longitude": -5.661133},
I would need to do a custom sampleMaker,
then bind it on my layers.ui.marker
where should I put the Json ?:
and your code should be a Transform script from the bindin?
	markers = []
		name = car['name']
				lat = dic['value']
				lng = dic['value']
	return markers
  1. So to use this method with a simplified json as:
Yes. That looks right.
Put that JSON into custom.vehicleStatus (or whatever you call it).
  1. I would need to do a custom sampleMaker,
Yes. It looks good.
  1. then bind it on my layers.ui.marker ...
No. The script reads it in the line,
There is no binding on custom.sampleMarker.
  1. Where should I put the JSON?
I think I have answered this in 1 above.
  1. ... and your code should be a Transform script from the binding?
See post #8, Figure 2.
I don´t know how to put the Json into the vehicleStatus, with Property, Expression...?
Your vehicle data structure is different to the original post. We need to modify:
Map - custom.vehicleStatus
    "longitude": -2.40938,
    "longitude": -1.639813,
    "longitude": -4.735528,
    "longitude": -5.661133,
Map - custom.sampleMarker
  "enabled": true,
  "event": {
  "icon": {
    "color": "#4190F7",
    "rotate": 0,
    "size": {
      "height": 36,
      "width": 36
    "style": {
      "classes": ""
  "lat": 25.938225,
  "lng": 49.938877,
  "name": "marker0",
  "opacity": 1,
  "popup": {
    "autoClose": true,
    "closeOnClick": null,
    "content": {
      "text": "",
      "view": {
        "params": {},
        "path": ""
    "enabled": false,
    "height": {
      "max": null
    "pan": {
      "auto": true
    "width": {
      "max": 300,
      "min": 50
  "properties": {},
  "tooltip": {
    "content": {
      "text": "5956 XJR",
      "view": {
        "params": {},
        "path": ""
    "opacity": 1,
    "permanent": false,
    "sticky": false
Map - script transform on ui.marker property binding
	markers = []
	for car in value:
		protoMarker['lat'] = car['latitude']
		protoMarker['lng'] = car['longitude']
		protoMarker['tooltip']['content']['text'] = car['name']
	return markers
Figure 4.
Figure 5.
Thanks for the explanation Transistor, one thing I´m missing is t know where to paste the Json in the custom prop. I guess is a tag but I not sure how to do so.
Which JSON and in which custom prop?
The three code blocks above Figure 4 tell you where to paste them.
this part
It tells you!
Vehicle status
