NCLOB in Alarm Journal - not in DB tables (Oracle)
Hi folks,
Ignition 8.1.24
Oracle XE 18.0
We're seeing event data showing up as "oracle.sql.NCLOB", while the actual data in the tables is correct:
And the columns appear correct:
It appears as though the auto-generated column type is a NCLOB, rather than VARCHAR. Is this something that needs to be changed?
Referred to both other threads on this (thread 1 and thread 2), but was unable to find a solution.
Short of running my own query to get the data and putting it in a table, does anyone have ideas as to how to fix this, or what the root cause may be?
Thank you in advance.
Ran this series of commands to change it from CLOB to VARCHAR. Picked a length of 500 to leave room for longer descriptions (my longest was 293).
--create new column
alter table ALARM_EVENT_DATA add ("strvalue2" varchar2(500));
--copy clob to varchar
update ALARM_EVENT_DATA set "strvalues" = dbms_lob.substr("strvalue",500,1);
--rename clob, then rename new column
alter table ALARM_EVENT_DATA rename column "strvalue" to "strvalueClob";
alter table ALARM_EVENT_DATA rename column "strvalue2" to "strvalue";
I was hesitant to drop the CLOB just yet, but it will happen once I'm content this is working.
Since this is a system created table, perhaps the folks at IA can make these changes for future releases?
Cheers!
Edit:
Used this command to get the max clob length for determining my new VARCHAR size.
SELECT max(dbms_lob.getlength("strvalue")) FROM ALARM_EVENT_DATA
