Slider Handle Offset from Cursor in Split Container
Similar to the two following topics:
I find issues when using a Slider inside a Split Container. Similar to this image by "steven.hodge" (topic 2 mentioned above), I can see a gap between the mouse cursor and the slider handle when dragging.
Interestingly, when the split container's position is dragged to "0%", the gap also decreases:
This behaviour is observed in Ignition 8.1.32, however, it's not observed in 8.1.38 (i.e. slider works without any gap).
Any insight into this is appreciated.
That sounds a lot like it's just a bug that we fixed?
Yes, potentially. Although, I couldn't find any information about it being fixed or even mentioned (in the release notes or elsewhere), hence reaching out for any insight.
Due to other reasons, we are unable to upgrade our gateways currently, so thought I'd just bring it up and see if others are having the same issue and to see if there are any workarounds for 8.1.32.
